Welding ground through vise?
ahansom
Santa Barbara
Is there a problem with grounding the welder through a vise? I usually ground directly to the work when possible or use copper jaws as the ground connection. What about just leaving the ground connected to the table and having the current go through the vise?
MongoTA
CT
It'll work. Often times I can't ground to the work itself so I go through the work table. Sometimes the table my welding table, soetimes it's just a piece of steel plate that I place whatever I'm welding upon.
sqznby
Coastal NC
I like the idea of making jaws with a larger piece of material as your grounding point.
If I can't ground directly to the material being welded, I have grounded to the vise.
I also have male pattern baldness
gte718p
A ground is a ground, but grounding through bearings should be avoided.
Unless you have some really weird slide mechanism on your vise, the least resistance path to ground is going to be the body of the vise, not the screw.
I don’t even clamp to the vise. To hard to get a solid connection. I ground to the table the vise is bolted to. Been working flawlessly for going on 10 years.
kerrynzl
Tauranga, New Zealand
Vices are terrible, because the shape makes it difficult to clamp to..
where my vice bolts to a wooden bench, I attached an "Engine Pull Tab" with the bolt.
My ground clamp easily attaches to this.
I used the engine pull tab because it was laying around, but any piece of metal strap would do.
Why not weld a piece of flat vertically off the bolt head.
