Somewhat true, but voltage does contribute to heat input. Heat input per inch of weld is measured by (volts x amps x 60) divided by travel speed (inches of weld bead per minute). The result is given in Joules of heat per inch of weld bead length. This does not account for thermal efficiency of the arc or heat lost to the atmosphere, but is a good point of reference for comparing the effect of changes in voltage, amperage or travel speed.Turning up the voltage will not make the weld "hotter". It will increase the arc gap between the work and the end of the wire, and it will appear hotter to our human skin and eyes due to the increased arc flash, but there is not any more amperage being put into the work.
I mean, yeah, it has to contribute, you can't have one without the other.Somewhat true, but voltage does contribute to heat input. Heat input per inch of weld is measured by (volts x amps x 60) divided by travel speed (inches of weld bead per minute). The result is given in Joules of heat per inch of weld bead length. This does not account for thermal efficiency of the arc or heat lost to the atmosphere, but is a good point of reference for comparing the effect of changes in voltage, amperage or travel speed.
Yes, I agree. Changes in voltage are a small number compared to amperage, so they don't result in as much change in heat as amperage. If you are running short circuiting mode at 16-17 volts and kick it up to 18 volts, that doesn't change the heat input as much as increasing the amperage by say 10-20 amps.I mean, yeah, it has to contribute, you can't have one without the other.
What I mostly mean by this is to address the old timers who just yell "turn up the heat!" and expect you to turn up the volts. Back in the day this was on a stick machine that had just one knob, the amperage. Since it is hard to discern an amperage change with a wire welder if the voltage doesn't change along with the wire, most people associate just voltage with how "hot" the weld is. If you turn the voltage up WAY too high, the wire basically explodes all over the place and you're left with the impression of "that was too hot" instead of "that's too much voltage for this wire".
Overall heat input is a different thing entirely like you've described. Usually much more a function of travel speed if everything else is set correctly.
Most people associate "heat" with penetration and overall soundness of a weld. "Need more penetration? Just crank up the volts!" Nah dawg, you need to up your amperage, and you adjust the voltage to get the arc characteristics you're after. Lots of factors affect penetration, not just volts.
When I was a teenager I worked at a general repair and fabrication shop. We mostly fixed cars, but we did machining and welding too. The guy who was showing me how to MIG weld for the first time told me "it runs best if you starve it a bit for wire". What I think he meant was he liked enough voltage to get a clean separation and good short circuit instead of pushing too much wire for the puddle to handle. And yeah, that's a roundabout way of finding out where you want to be. He did a lot of auto body work, and if your volts are too low it doesn't play nice on thin sheet metal.
All that to say, amps and volts are directly and proportionately related. If you increase your wire feed to get more amps, you need more volts to sustain the arc. Set the wire where it needs to be, then fine tune the volts until you get the desired arc characteristics.
