I would weld the crack you noticed first as you’re going to get some shrinkage out of that. Then, if heat is used I like to start with a heating tip on a dent puller. Again, a slower approach. If you want to use a torch, I would use the smallest tip you have on an O/A torch setup and heat up only about a dime sized circle at a time. Keep in mind, you don’t need to get things red hot in order to shrink. A golden tan (pre-blue) or blue is plenty of heat to yield shrinkage. Red hot and glowing does a good job of making mill scale and all the cleanup needed from that. So I’d shy away from too much heat.
Thanks Robert.Follow the same methods in using the laid over ruler and profile templates to keep track of where the high spots are…
Wait, so that ghost line was from an overlap of the two panels? Or was it a **** weld with a mig vs a tig?Daily driver or otherwise, I’ve always suggested that people use those “hidden areas” to practice and hone your skills for when you need to make a repair that counts, one that’s in your face visible. Using a method that yields a nicer repair, regardless of location, it becomes second nature and soon you’re able to tackle anything with ease.
Here’s a video to show the hazards of not having single panel thickness throughout a repair. Note the horizontal ghost line towards the bottom of this tailgate, shows EXACTLY where the repair occurred. It would have been no more cost in materials and perhaps only slightly more labor to have done this repair correctly to help prevent this from occurring, a blemish to an otherwise flawless restoration.
At the end of the day, your vehicle, your choice of repair methods. With the high cost of paint materials, just some food for thought to help get the best job done that you can. Rework comes out of my pocket, so I strive for the same high quality in the repair regardless of location.
That's what happens when you overlap two panels. Especially on a dark vehicle. The double layer of metal doesn't expand and contract at the same rate as the surrounding single layers and unless you have about 1/2" of filler on there to hide it the line at the top of the overlap maps through the paint. See it often when guys use adhesives and do overlap repairs that should have been welded in.Wait, so that ghost line was from an overlap of the two panels? Or was it a **** weld with a mig vs a tig?
That's a great idea. Thanks. I'm sure it's quicker than the dental pick I've been using.Plug weld cleaning bit that might help out:
I've seen the drill bit trick before but never tried it. Looks like it works well. I used to just scratch the plug weld hole out with a scratch awl but recently purchased these small brushes which also make quick work of removing epoxy or weld thru primer:Plug weld cleaning bit that might help out:
Good comments except the cooling/cracking. When steel is under 0.2% carbon it is pretty much immune to hardening by quenching. That said, some MIG wires can be up around 0.25% so possible the HAZ could be a bit hard and quenchable so nothing to lose by just letting it cool slowly in still air. I would not lose any sleep doing it either way (but knowing my wire's metallurgy and behaviour).With sheet metal the gap is not necessary, I try to have little to no gap when doing patches. The clamps work great when you need them but that is pretty rare. The trick is to do tacks, alternate around the panel and give plenty of time to cool, let them air cool and NEVER accelerate the process with water, damp rag, compressed air. Accelerating the cooling process will create brittle and weak welds that can crack later in time. As shown above you should occasionally grind down your tacks to see where you are at. Make sure the metal is clean, no paint, oils, etc., this will keep the weld clean. One thing that I will point out is in the pictures above the metal has epoxy primer on it, this will be debated but this is generally a bad idea. If it is absolutely necessary then make sure it is ground off about 1" away from the weld area, not only will it dirty the weld but it ends up needing to be ground off later anyways. As for wire size, .023 is pretty much standard, .035 can be used on the thicker metal but not all cars have 18ga. sheet metal. Clecos are a bad idea, this is not their intended use and flanged patches are a huge no no, they will retain moisture in the flange and fail in short order due to corrosion.
