Welding issues now with older eyes
GaryM909
Calgary, Alberta, Canada
If it's like mine--clips onto the back of the helm with what looks like car window trim--measure and mark the top center of the rim of your helm and the trim/clip piece on the cover. Makes it a hell of a lot easier to install the first try.
Now will someone invent a little blower to keep the lenses from fogging in the cold? I've tried every anti-fog substance known to man and still get fogging, especially between the lenses. There have been ski goggles with a tiny fan since at least the '90s, so why not a welding helm?
Maybe I'll have to buy a pair of those ski goggles and figure out how to hack the fan into my helm... if only I could recall what they're called....
When I was still working I spent a lot of time working up north in the winter. Wearing a hoodie made fogging worse. I wore a toque under my welding helmet so the was some air movement which really helped. Also wearing a respirator made a big difference but I always struggled wearing one (old school). Over the years I tried breathing through a straw and even a snorkel. I bought a small fan for a computer that I planed on rigging up about 20 years ago which is still in my drawer.
The younger welders mostly wear air purifying welding helmets and some sites even require them. I am not sure how they are for fogging in the cold but I would expect them to be pretty good.
v8nutz
rocklin,ca
I thought it was a light issue, no it's that I can't focus that close anymore. I wear progressive lenses and throw a cheap 3.25 reader over them, the two together let me get in real close. I need to check out the mag lens for the helmet.
Beerhippie
Far NE Oregon
You don't think it's a light issue. Bright light will cause your pupils to contract, effectively lowering the f-stop of your eyes and giving you a broader range of focus.
You can try this if you don't believe me: Make a little loop of your thumb and forefinger--like about 1/8". Put that up to your eye and look through it. You can now read at distances you normally can't! Same thing, different organs.
whateg01
doo dah, kansas, usa
I 3d printed a little housing for a small fan that clips to the top of my welding hood. It makes a huge difference with fogging. It runs off of 5v from a little USB power bank
Beerhippie
Far NE Oregon
Did you have to make a hole in the helm or is it inside? Seems to me you'd want fresh, cool air from outside blowing over the lenses--that's how the goggles work.
I'm considering ordering one of the units I posted above--but so far it has only one review. For $40, I'll wait and let a few other do the beta-testing.
whateg01
No it's just attached to the back edge. Ideally it would bring clean fresh air in but I'm more concerned with fogging than fresh air. It works fine
APEowner
Sunny, New Mexico
After several years of laying down welds by ear and muscle memory that may or may not land on the seam I was trying to weld I broke down and had my eye doctor write a prescription for dedicated welding glasses. The have a focal length of around 14 inches because that's a comfortable distance for me to weld at.
LopezBart
Lopez Island, WA
I find welding w/ progressive lenses almost impossible: lining up the material, the helmet and my eyes through the right part of the glasses just doesn't work for me. A pair of safety glasses that are 2.0 or 2.5 readers is perfect for me.
Beerhippie
Far NE Oregon
Like beerhippy I use a cheater lens and wear my readers, plus I have one of those HF magnetic base lights I shine on where I'm working.....that usually does the trick.
What gets confusing here is terminology, as we often refer to "readers" as "cheaters" hereabouts.
partsguy5768
Maybe a different better helmet? I wear readers while welding absolutely no issues. I can see very well.
whateg01
kimg0113-jpg.2298409
This is a cheater lens.
Fixr
SW VA
Yup. Since I turned 50 I don't tolerate contacts anymore, so it's progressive glasses. They get in the way, or are wrongly positioned when I'm welding. I really wish I could get just a -2 or 3 lens.
zenni.com $6.95 glasses. They'll make 'em with whatever prescription you want, just fill in the numbers on the prescription page. I'd buy several pairs with different strengths.
Beerhippie
Far NE Oregon
Thanks! I've bookmarked that page.
Now to get a new eye exam....
Beerhippie
Far NE Oregon
Now, what to do about aging, arthritic wrists and hands?
I can't lay anything but a stringer with the MIG anymore, as I can't move my hands/wrists in small increments. It's all or nothing. TIG is really a challenge.
Beerhippie
Far NE Oregon
My not be of any help, but I came up with this redneck setup when welding in dark areas on my exhaust system. miglight.jpg
Only laughing because I'm there, too. I've taped my little headlamp to the front of my helm at times. Actually, I like your solution better--more light where it's needed.
Olafur
Iceland
I was about to give up welding except under perfect circumstances. About a month ago I got ESAB Savage welding helmet. It shares the lens with the older Sentinel model that's the top of the line from ESAB.
Suddenly I can weld with my multi-focal glasses and pretty much see what I am doing. This thing costs 2-3 times that of the hoods I have been using in the past but it's totally worth it.
Moral of the story, some of you may consider upgrading, these things are not created equal. It's likely many other brands offer great hoods.
GaryM909
We used to tape cheap headlights to our welding helmets quite often back in my boilermaker days. It worked pretty good mind you that was 25 years ago.
chubby one
So any old blokes got any good tips for welding with older eyes?
I used to do pretty good but now using glasses behind the welding hood it's hard to see what i'm doing.
I`ve tried illuminating the work area more which helps abit.
Just looking for useful tips.
I have found more light on what lm welding helps me.
BigMike782
For my situation I found that an ESAB Sentinel with the yellow front cover plate gave me the best optics. Before that I used a Speedglas 9100 and it worked very well too.
I wear glasses for distance but take them off to weld(and read and see up close and all other sorts of annoying things)
Fixr
SW VA
Just wait until you start to develop an Essential Tremor.
Makes degrading / changing eyesight seem like a minor inconvenience.
Propranolol helps somewhat with mine. Unfortunately for my TIG welding, the shaking tends to be more up and down than side to side. Makes holding a short arc very difficult.
txvwnut
Bedford, Texas
I ordered a cover for my helmet as I too am having issues seeing the puddle. I tried a lot of what has been suggested above and have come to the conclusion that I’m getting glare off the shop lighting. I ordered a cover for the back of my helmet and it ever shows up I’ll try to remember to report back.
Cover finally showed up and it's been quite the improvement. It was as I thought I was getting glare inside the helmet from the shop lighting and depending on the time of day sunlight through the windows.
Beerhippie
Far NE Oregon
And you can skip the welding cap--no more spatter down the back.
MichaelP
IL/WI border
But is you stay sideways, you'll be stacking dimes whole day long.;)
toplessHO
central florida
"pinholing"
