Welding nuts trick?
Kaizen
New England
I am welding two one inch nuts and a one inch bolt to tube. The nuts are stationary and the bolt will raise and lower for an adjustable leg. Any trick to keeping the threads clean? Cover the exposed bolt threads with something? I do have the bolt in the nuts so I don’t have issues with alignment
Bigblue&Goldie
If coated (zinc, galvanized, etc.), sand it to bare metal. Weld it on as is with a few heavy tac welds. No need to weld the whole circumference. Regardless, a course thread nut/bolt of that size should still have a reasonable fit if you don't go overboard with the heat input.
xela456
Have an oxy/fuel torch? if you blacken it with the acetylene soot the weld spatter wont stick to it.
MoonRise
Coat the threads (male and female ) with anti-spatter spray.
PAM cooking spray (or whatever brand cooking spray you have ) usually works too.
Or a nice generous coating of Never-seize on the threads.
Thread bolt into nut(s) and make sure that you don't 'jam' the nuts together.
Remove any coating (galvanizing or anti-spatter or PAM, etc) from the area on the nuts where you will weld.
DO NOT WELD CADMIUM PLATING/COATING !!!!!!!
danielbuck
I just put a bolt or short section of all thread in the nut when welding it, haven't had problems doing it that way. I usually just grab an old bolt and use the same one for all of the threads, so I don't mess up new hardware. All thread you can cut a slice down the center of the end and use it like a large flat head screw, and you can screw it all the way down flush with the nut, if space while welding is limited.
Not only does that keep anything from getting into the threads, it also acts as a bit of a heat sink to hopefully not get the nut hot enough to warp.
If I have enough time and forethought, I soak the hardware being welded in vinegar for a day or so to strip the zinc. Keeps the fumes and spatter down.
Just in case you do get something in the threads or if the nut gets hot enough to warp (which it easily can) have a tap handy, or at least a thread chaser if the nut gets too snug.
tarmy
Nor Cal
As others mentioned...center the nut with the bolt in...in the hole. Tack and check for clearances, weld up. This photo shows how I put handles on the bolts too...
ItsNemo
Canada
Yup, this. Easiest just to throw a bolt into the nut.
jjeffries
That welding table is a work of art. Ultra cool. John/CT
jimgood
Marshall, VA
Worst case, if some BBs get into the threads or they distort a little, you can always run a tap through the nuts afterward.
kerrynzl
Tauranga, New Zealand
Coat a bolt with "Zinc" anti seize and screw it into the nut. I always use the bolt to centre it into a slightly oversized hole and then weld the nut.
Now I always have a correct sized socket set-up in my cordless impact wrench.
As soon as I've welded the nut, I quickly unscrew the bolt [before the nut "heat shrinks" and damages the thread]
K
Kaizen
New England
That is some nice looking welds sir. what do the handled bolts do? Does the top slide and that locks it in place?
MoonRise
I'm not tarmy :lol: , but those red-handled bolts are there to lock accessories into place in the receiver hitch tubing.
tarmy
Nor Cal
Yep!
I have various implements that slide into the receivers...vice, table extensions, etc.
Here is some eye candy...
