Welding on a Modern Car
dkroth
Rochester, New York
I've got a few rust pin-holes forming on the quarter panel of my 1998 BMW. Am I OK weld them up with my MIG unit? Is the electrical inteference from the welder going to kill some/all of the electronics in the car?
Where's a good place to connect the ground from the welder? I'd like to do it as close as possible the the welding site rather than the battery or engine. I want to minimize the current flowing through the car body and wiring.
jhelrey
MN
I always see them connect it to the area where they are welding and not only do they clamp it, but they weld their clamp to the car.
sberry
Brethren, Michigan
Clamp ground to the piece you are working on.
NOT to battery or engine unless you are welding on it.
atari
Carroll, Ohio
Totally disconnect the battery and ground the welder reasonably close to were your welding. I would not weld the ground to the car, its kinda overkill. They make magnetic clamps that work really well. They have a magnet ring and a spring loaded pin in the center that the welder grounds through. Some times its easier to use than the clamp style on sheet metal. I have welded on a bunch of cars, in fact I just welded the sub-fame back into an E36. Be happy that you only have a rust issue, It could be worse.
sberry
Brethren, Michigan
I think there as many problems caused by connect/disconnect. Have welded on hundreds. probably thousands of cars, never do it. Trucks are used as welding platforms every day.
topnos
Houston, TX
Yeah, this is the cheapest way out.........doesn't cost a dime.
At work we use the Mac tools ET20AZ Anti-Zap so there's no need to disconnect the battery.
The Mac Tool Anti-Zap is the way to go. Easy to use and ensures no eletrical surge damage to ECUs or other sensitive electrical equipment. I have one and used it a lot without 1 electrical problem.
