Welding on a Propane Tank
racecougar
Missouri
I work for a company that builds propane tanks, and I'm certified ASME and DOT. I wouldn't worry about the oil getting into it, as much as I would the risk of altering/welding on the tank. The steel itself is pretty thick. But every one of those tanks have to pass through X-Ray, to ensure there's no porosity, slag, undercut, non-fusion ect. There's no way I would fill that tank again, and anyone in there right mind wouldn't do it, as it's been altered. The only thing it's good for now, is maybe a charcoal grill or something!
This thread is nearly 13 years old. The OP's friend has likely made a decision by now.
Walkers
Cave Creek Az
Doh! First post and you drug up a thread that was dead for more than a decade! Welcome aboard, but try to stick with the 'New Posts' button for a wee while until you get used to things.
ez-duzit
Marina del Rey
Exhaust gas is not an inert gas. It is a risk to use it to purge a tank that contained something combustible/explosive.
Is your friend an ASME code certified pressure vessel welder?
I say the tank is now scrap metal.
This. It was a foolish idea and completely unnecessary to weld on that tank.
nadogail
Coronado, CA
The idea of carbon monoxide being an inert gas totally ignores the Gasogens that powered internal combustion engines when liquid gasoline was not available.
Cars, busses and trucks were ran on the smoke from wood and charcoal fires.
mike93lx
Richmond, VA
You joined to give feedback on a 13 year old project?
Welcome
Metal-Marc
Foothills of the Adirondacks
That's a 13 years old thread and OP is long gone.
So, are you a spammer?
driftpin
I work for a company that builds propane tanks, and I'm certified ASME and DOT. The only thing it's good for now, is maybe a charcoal grill or something!
I recall being on the road in the fire-rescue jurisdiction where I worked, and I saw some people doing some 'hot-work' cutting down a 55 gallon drum using a torch.
"What'cha doin' there?" I asked.
"Makin' a barbeque grille!" they replied.
I couldn't help but notice the prominent label on the side of the drum. I guess they knew what they were doing.
Maybe not.
johninct
He is either the bravest man or the dumbest . Why I say that, a church blew up a mile from my house and my house shook as if someone drove a car into it...
