I have a two year-old vertical air compressor that stands on two wheels on one side, and a U-shaped bracket with rubber feet on the other. The factory (very crappily) welded the bracket to the outer tank at two points. One of these welds has broken off. When it broke off, the bracket left all of the filler material behind on the tank surface. I would like to repair it with my trusty HF flux core welder loaded with Lincoln wire.
Before starting this repair, is there anything I should be aware of, or is this a straightforward job that I think it will be? I just want to observe a bit of extra caution around things like pressure vessels. TIA!
And once again There will always be members that will tell you not to do this but in reality it's done all the time and even members here that have welded there tanks with no problems.
