Welding On An Electric Motor
Bib Overalls
Jonesboro, Arkansas
A weld on my ban saw's motor mounting pad has cracked/failed. It wasn't welded all that good from the factory in China (where else) and the only remedy that I can think of is reinforcing/fixing the existing welds is more weld.
I know that the ground needs to be located where where the current does not flow through he bearings and/or arc inside.
Will this work or is there something else I need to do before welding? I am not particularly adverse to taking the motor apart but I will do it if necessary.
Bert_
NW Iowa
I would ground to the mounting plate and I don't think you will have an issue. Maybe do a couple short beads allowing it to cool in between.
larry4406
Northern Virginia
I’m no welding expert
I was at a power station were welding on a diesel generator frame was needed. Same concern over arcing across bearings causing issues.
The brain trusts at the plant said to connect the ground clamp as close to the weld site as possible. They explained this would prevent the discharge path going thru the bearings. I do know machine ran ok afterwords but no clue if any long term impact. YMMV.
Milton Shaw
I welded a bracket on a motor several years ago, short welds and let cool.. No problems have used it nearly twenty years now. So give it a try if its out of warranty. Ground to the bracket and you should be OK.
nadogail
Coronado, CA
As the others have said, avoid having the welding current pass through bearings, bushings or brushes. The shortest path to ground and short beads with lots of cooling are also important.
dogdog
I would worry about melting those winding (wire insulation) than worry about ground... as long as you disconnect the power and the caps... Not sure if welding current would pass through the bearing unless you clamp on it...
have a 2HP where the UPS monkey throws around like a step child and broke the casted legs that way.
