Nhrafan26
Ok, after reading on here I have noticed mention of welding outlets, and ONLY outlets labeled as such, can use smaller gauge wire for a higher amp breaker?
Is this correct? Reason I am asking is that I want to run a welding outlet over to my garage doors for doing work outside which will be full gauge #6 to 50 amp outlet to cover anything i want to plug in there. BUT I also want to run a welder only outlet to the back of the shop and if I can run a smaller gauge wire and smaller conduit that would help save a little $ and some space.
The run will be approx. 40' in conduit under slab from wall to wall.
These are the machines that would be plugged into the outlet:
What size wire can I use for just this outlet?
Welder #1
Input Voltage: Single-Phase 110vAC or 220vAC (±15%) @ 50-60Hz
Input Amperage: 28 amps
Output Amperage: 10-200 amps AC/DC
No-Load Voltage: 51
AC Duty Cycle (%): 20-80 (80% at 100 amps, 20% at 200 amps)
Post Gas Flow: 2-8 sec.
Pre Gas Flow: 0.1-1.0 sec.
Efficiency: 80%
Plasma cutter #1
Input voltages: 120-240V, 1-PH, 50/60 Hz
Input current @3.8 kW: 120-240V, 1-PH, 25-18.8A
Output current: 15-30A
Rated output voltage: 125 VDC
Duty cycle@ 40C (104F) 35%, 240V 20%, 120V
Open circuit voltage: 256 VDC
Power supply type: Inverter – IGBT
Welder #2
Input voltages: 230V/60Hz
Input current: 21A
Duty cycle: 30% @ 230V/60Hz
Rated output: 130A
Volts @ rated amps: 20
Power cord: 50A 250V NEMA type 6-50P
Welder #1
No-Load Voltage: 51
Efficiency: 80%
Plasma cutter #1
Welder #2
Input current: 21A
Rated output: 130A
