Weld DC straight polarity. Pay attention to the electrode numbers for whatever you use. First two numbers designate tensile strength, eg 70 = 70,000 psi. Third number designates position 1 is all position. And a combination of the third and fourth numbers is the flux composition. Not sure what electrodes you are used to welding with though. Me personally, would use a 1/8" ER7018 electrode running about 120 amps. (just the ironworker in me)
You are also going to want to a) groove out the crack, and b) drill a 1/8" hole at each end of the crack before you weld otherwise the crack could spread after the repair is complete.
Good luck with your repair.
