Welding: Protect benchtop/floor from heat with HardiBacker?
Bolster
Mexifornia
Guys help me out here...I need to do some welding of 1 or 2" square tubing with my little oxy acet rig, but I don't have a good surface to lay out my project on. I need a couple square feet of good working space to do it. I don't want to burn my formica laminated fiberboard benchtop (obviously), and I don't want to set the project directly on my shop's concrete floor.
I have a large piece of 1/2" HardiBacker Cement Board left over from a job, I would like to use that if possible, no additional investment needed. What do you think of using that as a backstop for my welding project? Will getting HardiBacker hot, cause any unforeseen consequences?
snorky18
Southeast Tennessee
You thinking of putting the Hardi on the cement floor or on the laminate bench top?
I would think it would be fine, especially if you're just talking about incidental flames from the torch hitting the Hardi ocassionally. Main thing is not to burn yourself on it; it will probably stay hot for a while.
If it were my house, I would experiment with it (with garden hose / fire extinguisher ready just in case) and see if there are any adverse affects.
blazemaster83
Lacey, Wa.
I work as a glass artist, and I use hardibacker for my benchtop. It can take some serious heat. I lay molten glass on it all the time. If i can lay a 1 inch molten chunk on it, and everything is ok, i think youre fine.
The only thing i dont like about it is it can start to break down after a long time, and gets everywhere.
Bolster
Mexifornia
Cool!
I was going to place the HardiBacker on my cement floor and just work there...or possibly suspend a piece of 3/4 ply over saw horses and then place the hardibacker on top of that, if the work pieces are short enough that level doesn't become an issue.
I do know that you don't want to be breathing free-floating HardiBacker dust. I recall it is a silica product. I always wear a 95 NIOSH-style dust mask when cutting or drilling it. So I assume long-term flame may disintegrate it, and it's probably a good idea to wear a mask if the HardiBacker is disintegrating. Cheap enough you can just get another piece of it if it starts to deteriorate.
Iron-Iceberg
A-town
I have a 2'x2' piece with a length of alum. angle screwed to one side. I clamp it to the edge of my bench when Im grinding to keep the sparks from shooting all over the shop.
