Welding questions
06switchback
Ok I'm not a welder its just a hobby / necessity because I'm to cheap to pay someone to do it
I have a Lincoln 255 mig
most of the time my welds look pretty good but lately some weld look good and others are very porous with bubbles and pin holes in them and a lot of times a bubble that I can watch grow while the weld is still hot but after I have let off the trigger and then the next weld looks great what am I doing wrong
It happened to me again today these welds are on the bottom of my bush hog I know they are not the prettiest but will be fine once I hit some rocks they will be ground flat
Any tips advice or ridicule would be appreciated 06d1d56fa67b1e1516f13337b61f6445.jpg7c025ff6c59656591598cfd20170e059.jpg652c24e62ccb7a67fd4a2753dcbba875.jpg
Sent from my SM-G970U1 using Tapatalk
Duker
Livingston, TX
I will bypass the critiquing of the welds to those more knowledgeable than myself as I can weld but I am not a welder. I do have the same machine however and I can tell you what issues arise on my machine and maybe your machine has the same trouble.
1.) Unlike my Miller or even my Lincoln MP210 the Power Mig 255 really needs a good ground. I can tell within 2 seconds if I have a bad ground connection. I replaced the ground with a 300 AMP clamp but for some reason it has always been an issue.
2.) I suspect because of the ground issue the surface metal needs to be clean again more so than my other welders. It can be hit or miss on a bead or two where one is fine and the other looks like Fido's **** as Jody would say...
Looking at the pictures I would venture to say a little more grinder/flap wheel prep might help.
3.) Clean wire.. If my Flux wire has been banged around or has some dirt on it from sitting on my shelf under the welder it will have spots where the puddle doesn't flow well.
I don't know if any of this will help but those are issues that have affected the beads on my Power Mig 255.
tarmy
Nor Cal
Clean material, good ground contact near the weld area, enough heat and speed (learned by practice mostly) for the application/penetration...
f150skidoo
Ontario, Canada
Wormholes in the bead will most of the time come down to contaminated material such as rust, paint, etc. Or not enough gas coverage.
06switchback
I know I didn't spend a lot of time cleaning and grinding on these welds because they are on the bottom of a mower
I did follow all the cracks with an angel grinder to make a v before I welded them I didn't clean the edges
I was welding some cracks in my brush hog its 12 or 14 guage sheet with bracing welded on the top it cracked following the factory welds on the top
The wire should be clean i didn't look at it yesterday but I put the roll on about a month ago its .030 I usually use .035 but bought that by mistake so I'm using it
Thanks for the response
TNToy
West Tennessee
Doesn’t matter what you’re welding. If you want it to hold with a MIG, clean everything before you lay a bead
BD1
north side
As stated, gotta clean that metal and clean for good ground. If welding outside with gas, try protecting the welding area. Gas is blowing away.
That glob in first picture is pulling away as you release trigger. Release trigger and then pull gun away. Good luck.
bdbecker
Iowa
Dirty base material. All the impurities are boiling out of the puddle while its trying to freeze. I'd definitely grind those out and redo them - those welds will not last long. If you want to avoid this in the future, prep the joint down to bare metal before welding.
Jazz1
Thunder Bay On.
Clean the steel you going to weld will improve your welding whether using flux core or shielding gas. As stated wind will affect gas causing holes or you could be moving too quick. Take your time, you're getting penetration which is critical, not ready for the big time yet.
My boy welding, 12 hour shifts in 45C heat past July. Each weld has to be perfect on boiler tubes,they are x rayed for quality...
Copymutt
Colorado
I fought worm holes on a custom exhaust mod for days. Finally realized the soot/ carbon from the inner wall was the cause.
Monza Harry
Windsor ON
I fought worm holes on a custom exhaust mod for days. Finally realized the soot/carbon from the inner wall was the cause.
As mentioned above the other side matters, the paint that I presume is there can catch fire [and the grass on that side]* and draw the air into your puddle with the results you pictured, usually on the same side for me but unwanted air is your enemy on either side. Harry
*And even my coat being on fire didn't help some of my welds, we know these things from,... we'll call it "experience"!:shocking:
06switchback
Maybe you guys were right gotta stop being lazy and do some more grinding da2cae2d29b713d53930ff00af25a76a.jpg
bdbecker
Iowa
Maybe you guys were right gotta stop being lazy and do some more grinding...
Its worth noting that most everyone (myself included) who commented about needing to clean up the joint before welding had to learn that lesson the hard way. Glad you got it sorted out!
Bigblockyeti
Upstate, SC
You don't even necessarily need to grind every time, a knotted wire wheel on a angle grinder can clean up some seriously nasty stuff pretty quick in one pass.
06switchback
I know i have a couple wire wheels but the grinding wheel was on the grider
Iron Beaver
It was a revelation to me how much better my welds looked after good material prep. I, too, learned that the hard way.
Joemctag
Outside raleigh nc
And while you’re at it you can grind or buff a spot for your ground clamp and just hit that with the spray paint too, after. Rust seriously prevents a good weld, and with SMAW, too. I, too, couldn’t believe your welds could look that clean, considering.
Aviatordave
I weld a fair amount. I don’t do it professionally but I did go to school for it. Everybody here is spot on. Clean your metal for MIG. Make sure your ground is on bare metal as well. Rust will conduct but not well if it’s flakey and thick. Don’t know if you’re welding inside or outside but if it’s outside, the wind can blow your shielding gas away and produce a crappy weld as well. Looks like you’re on the right track now.
Good luck!
