Formerjeeper
Have some female hex differential drain/fill plugs that are stripped, plan is to weld a cheap socket to them and break them loose. Does it matter whether I use a chrome or impact socket?
Or a bolt.why wouldn't you just use a nut?
Biggest issue on some pans is, you have to be careful not to damage the threads in some fairly soft metal..Have you tried using an air hammer with a chisel bit on it to knock it loose?
