Snip
So I found the material for the top, 1/2" plate 6'x8' and the legs 3 1/2" square tube. Found reasonable at different locations on Marketplace. I will most likely cut the top down to 4x8, 5x8 at the most. I will be using 6 legs. My thoughts are to leave a 4-6" overhang for clamping and doing a sub-structure under the top, one permitter band connecting all of the legs and then cross bracing the 2 sides together. Trying to eliminate as much "bounce" as possible in the table. The two options I am looking at would be either 5x3/8" flat bar placed vertical or 5x1-3/4 channel with a .190 web. Price wise not much difference, 25.00 a 20" stick. Which do you think would give the least bounce/rebound? The top will be welded to the frame, I'm 61 so the odds of needing to replace it while I'm here are slim.
. I got it pretty close to straight with heat, but it still bugs me a decade later. lol
