Grinding- wheel
Ive got to make a couple welds where the angle is very small so its difficult to get down into the joint. Im saving for a nicer MIG/FCAW machine. Well specially a Millermatic 211. Right now I just have a cheap FCAW only machine as well as an old 250 amp AC/DC machine.
So long story short Ive got a welding project Im trying to complete. One of the welds I have to do has a very tight angle. I wish my stick welding was up to par. Because this would be perfect for a stick machine. I recently started welding again after a very long time of not doing it. Anyway I set my machine up to the chart parameters. If I shove the contact tip down in the joint so I maintain the proper stick out I inevitably stick the contact tip to the metal. If I hold the gun back a little to keep from sticking the contact tip Ive got to use a much longer stick out. Which obviously causes lower voltage and issues of its own.
In a situation like this if you had no option but mig or fcaw it is it acceptable to crank up the voltage to compensate for the stick out? The weld acts just like it needs more heat/voltage. Or will that cause a problem with the wire melting to soon due to the increased resistance? Im running .030 wire the little machine Ive got can run either .030 or .035. If having to use a longer stick out than normal would running a larger wire make any difference? Also would the wire feed speed need to be increased? I would not think it would but just asking.
Im planning on setting up some practice pieces today to mess with the settings but I wanted to see if their where any issues with long stick out besides the obvious.
Thanks
Thanks
