Welding wire question
Skyline
Last weekend I bought a nice Miller MIG welder, mainly because it came with a spoolgun that will work with my Millermatic. I have a buyer for the welder for exactly what I paid for the package, so.... FREE Miller 30A spoolgun ($1,212 on Miller's web site), plus a bunch of aluminum wire spools and tips. Can't go wrong with that kind of deal. My question is about the spool of wire that came in this welder.
This wire is copper colored. But the copper color appears to be just a coating, and wire itself is silver colored. Can someone tell me what this is? There is a label on the spool, but it has just a code no. and the size...no description.
Monte
Germany
steel welding wire is usually copper plated to prevent the steel wire (silver) from rusting.
35mastr
Norcal
Does it have a hose and a regulator attached to the welder? The wire could be flux core wire.
Is the wire on the welder or in the spool gun?
ears
lorton VA
Steel mig wire is copper coated. It helps in manufacturing and it prevents rust. The code should tell you what type of wire it is, probably er70s-6.
Edit to add I type slow. Monte's got it.
Skyline
I have not had my own welder for that long, and my MIG has wire without this coating. I guess it comes both ways. I'll post the code tomorrow.
Skyline
The welder is set up for a tank. This is on the big spool inside the machine.
ears
lorton VA
It sounds like you stepped up to solid wire, which is almost alway coated in copper. It is available uncoated but rarely is it on the shelf so to speak. You must have come from a flux core machine which uses uncoated wire. You will love the difference.
Monte
Germany
If your place/garage is always warm/heated it should be no problem if you use uncoated wire, if you live where you have a high humidity you should use copper plated wire.
GN4WHLN
Alta Loma, CA
Hmmm... my aluminum wire is silver. It's also soft. If your wire is stiff it is probably for steel. Maybe the wire was mispackaged. Typically, I use ER 4043 wire.
BTW, copper is not only for rust, it is an alloy element that makes up part of the wire's welding characteristics. It also aids in feeding through the gun and allowing the drive to grip the wire.
Skyline
This wire is maked: Imperial 75
Heat: F44257 Dia.035 Net: 33SPL
ears
lorton VA
Imperial 75 would be the brand or name of the wire.The heat number is a lot number. When they melt the steel it is called a heat, they test some of it to see if it passes AWS specs and then give it a number before they make the wire out of it. 33spl I assume means it is a 33 pound spool, a common size.
