Well, my Epoxy-coat project is done
OneAkela
Here's my saga for for future generations:
The garage is a new construction about 440 sq. ft. I started out by smoothing the edges of the expansion joint groove with a Kobalt rub brick from Lowes.
Swept the floor and blew it out with a leaf blower. The next step was filling in the expansion joint with a quarter inch backer rod, then Sikaflex SL. That stuff is pretty neat. It is a 20 ft groove that needed two 10 oz cartridges. The stuff levels out, but gives a slightly concave surface. I considered leveling off with Rustoleum epoxyshield, but I did not have the time.
Day 2 was acid etching. I used the solid powder that comes with the kit and also used hydrochloric acid. I wasn't sure if the acid was having any effect. Next came the neutralization with ammonia. I used a quart (I think) in two batches, spraying from the sprayer. Next washed with water. I thought ok, now to squeegee the water out... but guess what? I had bought an 18" squeegee from Lowes, but the darn thing had no threads to affix on the pole! I thought, ok, not a deal breaker. I will just use the sqeegee that comes with the Epoxy-coat kit. Well, that doesn't have threads either! Gaffled by both Lowes and Epoxy-coat! Last resort was the notched sqeegee. I used the back edge to push out water, as best I could. Then I used the leaf blower. Let dry overnight. I came back the next day to find all sorts of marks, mainly footprints on the floor. Also there was a dark gray residue on the floor. I used a wet sponge mop to clean in straight lines.
Day three was applying the primer. I used Elitecrete's VB-5 primer that is a 2-part epoxy that is diluted with water. I started out making the stuff in a 5-quart pail. Put half the stuff in a Wooster Big Ben paint pan lined with aluminum foil. I used an 18" roller and things were going swimmingly. After a while though, I saw that the primer in the pan was bubbling and looked like a delicious dessert pudding of some sort! I realized that it was gelling up, so I went to the balance of stuff in the pail and in a panic, I dumped it on the floor. Well, it had a giant glob of gel in it too, which promptly proceeded to stick to the floor! I quickly picked up what I could, made a second batch and finished the floor. With advice from Gene from Elitecrete, I sanded the lumpy stuff the next day to clean it up.
Day four was the real test. I put Part B in 4 5-quart pails (a hole was drilled at the edge of the lid to facilitate pouring) to make 4 batches. Started the first batch and dumped it on the floor in S-shaped patterns. Started the rolling. When I was satified with the neatness, I threw on the paint chips. Terracotta red, white and blue. Did one section at a time. Unfortunately, I had used up both my 1/4 in nap rollers on the primer, so I was using a 3/8 in nap. I was getting lifting of the epoxy on the last batch. Only happened on one end of the roller, so I was able to fix it. Also, the last batch seemed a lot stickier. It didn't help that it was 95 degrees this weekend in central Virginia...
In the end, I do have some thicker spots where I may not have rolled properly, but the paint chips make it not noticeable.
I drew on the experience of members here and advice of the pros. This is an excellent forum for learning. I hope my meager experience will aid others. I am going to try to post pictures if I am able.
Big-Foot
Midlothian, TX
I think that's the first time I had ever read of someone priming the concrete before applying Epoxy-Coat. I never primed mine and so far so good. The important thing is that you're happy with the results..
Baada
Eastern Missouri
I really wish I had primed mine first. I think it would have eliminated all my bubbles from the little pinholes after grinding.
Motofixxer
BTW, that is one large joint you filled. Never understood why some of them are so large.
