Radix2
So my wife's uncle came over to help me diagnose it. We closed the valves to the house and pressure tank. Well kicked off at 46 psi like it's set to do. Then over an hour it dropped to 43 psi, he thinks it's the jet or the foot valve with a slow leak or crack. I'd rather that than the well running dry for sure. What says the hive?
Sent from my SM-G965U using The Garage Journal mobile app
Yes, you have a slow leak somewhere.
But that does not seem to explain your original issue here. The leak back will add some cycles to your pump, but it doesn't explain you not having the flow you used to have. At this point I go with wear in the pump, if it is getting old and is a decent Gould pump, I'd rebuild it and see if you get your capacity back. Replace your topside check valve if any, and when it makes sense look to the foot valve.
You could at least order a set of seals, and open the pump up and see if there is corrosion, wear or some type of blockage that can addressed. You got to start with the easy stuff before pulling the pipe imo.
