Yard projects are in full swing at our household right now. It's so weird not having barn stuff to do. Weird in a good way for sure.
Anyways, we are putting in a 15x30 oval out of ground pool this spring, which requires the wife's garden to be moved across the yard to where the kid's cabin used to be. The kid's cabin (which they'd outgrown) was disassembled and I'll use materials for this and other projects.
I can recycle many items from the existing garden, but will be making new raised beds. The old ones were just dimensional lumber, and worked fine while she was learning about gardening. Now that we know she loves it as a hobby (and the whole family enjoys fresh salads etc.) the next garden will be a bit better thought out and implemented.
Firstly, the raised garden beds will be constructed of 4" thick x 8" wide x 16" long solid cement blocks. These blocks are often used as spread footers under sheds, or as caps to cinder block walls. In this case, I'll tip them on their sides for a permanent installation. Full cinder blocks would be more stable, but they're uglier and take up planting room. In my case, the entire perimeter of the beds will be supported on the outside (by the fence, or by the walkway) and will have dirt obviously on the inside, so stability should be fine. This setup will never rot, so I won't have to do this again. Under each raised bed, hardware cloth will help thwart the mole/vole popluation.
Secondly, as part of my overall mission to make mowing and string trimming as efficient as possible, the non-bed portion of her garden area will be a deck walking surface. The runners that I will attach slats to are recycled split rail fence components, and the slats are recycled PT 2x4's from other projects. Once assembled and stained it will look nice, and eliminate the need for me to maintain anything inside her garden area.
For the fence, we have most of it already from the old garden, but will need to pickup a few sections. I'll make my own gate out of something I have laying around. The interior of the fence will have some wire to discourage rabbits from coming in for a snack. Deer aren't in my neighborhood, so we're good there.
Overall, we'll have about 120 square feet of planting area. This is more than she had in past years - and in those years we had plenty of crops for salads, pickles, salsa etc. The wife has gotten smarter about planting too - focusing on manageable varieties, and items that will be either eaten real-time, or can be converted to other uses. For example, peppers and onions are good crops because you can cook with them or eat them raw today, or you can can them in sauces or salsa for later.
Around the perimeter of the garden fence, she plans some blue berry bushes and flowers.
Edit: I can't get the attachment to work, so I'll describe it instead. The layout is a simple horseshoe design with beds around the perimeter on 3 sides and a gate centered on the 4th side. In the middle, is an "island" bed. This layout allows the fence or the walkway to support the bricks of the raised bed, and allows my wife easy reaching distance to the deepest portions of all the beds. The walk way is plenty wide enough for her to kneel on comfortably, or even to have a stool to sit on to admire her garden.
So far, I have the old garden down, the new area prepped, and one fence section installed.
