There is some good discussion of these here. Mine looks just like the one pictured in this thread: https://www.garagejournal.com/forum/threads/westinghouse-1byc-compressor-retro.485826/
The only manual I've been able to find online is this one, https://npeinc.com/manuals/General Electric/GEBK-IBvendor/WABCO.PDF covering somewhat similar "VC-WC models." Can anyone point me to a manual covering this model specifically?
I think I now *mostly* understand how the oil pressure operated unloader works (but what is the ball check valve in the upper fitting?), EXCEPT:
The air discharge is plumbed directly into the tank without a check valve, and this is also what the manual mentioned above shows. But this doesn't make sense to me. What prevents the entire contents of the tank from discharging into the crankcase? Surely there needs to be a check valve??
And is there a way to measure the oil pressure and what should that pressure be?
Thanks for any guidance!
