wet edge
jsmith6752
Southeastern PA.
I am stripping half of my new 2 part epoxy floor. (100% solids) I am not happy with the appearance. I am chemically removing it and etching again. I plan on running tape down and stripping to the edge. i can then run a wet edge when reapplying . Will that be very obvious ? It will also get a 2 part top coat. I hope the small amount base coat after stripping and etching will not be a problem. Any thoughts or suggestions would be appreciated. thanks
LegacyIndustrial
deerfield, IL
It will be obvious. If you have flaked it it may be less obvious.
tncatadjuster
Memphis, TN
If you can do a great job of blending the seam, it will diminish to some degree with use. All depends on what level of perfect you want.
