Hello,
I live in Canada and house was built in 80s. The climate this winter has been very mild and my 2 car garage is constantly very high humidity. This is typically seen every spring but due to mild winter, it's been months like this. The garage walls are insulated (spray foam), ceiling blow-in and the garage door is insulated. I purchased a dehumidifier (Alorair HD55) which works well at pulling moisture but the garage floor remains wet and humidity high. I'm not the original home owner so I can't say if a vapor barrier was installed underneath the slab but my guess is no. I can say with certainty that thye used pre-cast hollowcore slabs for the flooring. I'm sweeping the garage floor daily and puddles are being pushed out, only to show up again not long afterwards. I'm trying to limit the amount of snow we bring in. I kick and remove as much snow off the cars before parking inside. I have a large 36in industrial fan to move air and a 5kW heater.
Would there be any added benefit to seal the concrete floor to limit the moisture wicking through?
I appreciate any help.
