HarleyStBob
- Joined
- Dec 29, 2009
- Messages
- 3
Greetings from Texas Gentelman. I have a question on a recent air compresseor set up I installed. I have installed a Sears 80 gallon air compressor which is rated at 5 horsepower and will churn out a maximum of 175 psi in my garage with four air outlets. Each air outlet, I had planned, was going to have a specific purpose so I installed four Craftsman air regulators/filters, rated good up to 175 psi, on each air outlet. The problem is when I turn the air compressor on I can not control the pressure on the four air regulators/filters. The air regulators/filters make a hizzing sound and indicate pressures between 150 psi to 175 psi and no matter how many times I turn the knobs on the air regulators/filters the hizzing sound will not go away. I simply can not control the pressure on the four air outlets. What am I doing wrong, do I need a "master" air regulator on the compressesor to help me control the four air outlets? Suggestions are welcomed as I am fairly new at this. Thank you in advance.
