Jakemedic
Greetings from COLD Iowa. I am in the process of quoting out a pole barn for use as a woodworking shop as follows:
I got two quotes for the building. One from a local builder with a reasonably good reputation for producing a good product and one from a builder about 60 miles away.
Both are using 29 ga steel, 8' on center posts (except for the last opening which would be 4'), 4 inch concrete with rebar and expansion joints cut.
Local builder is 18,120
60 mile away builder is 23,600.
The only noticeable difference between the two is the local builder is using 5' on center for the trusses and the other builder is using 4'.
What am I missing here?
The building won't be built until spring (mostly because my dirt work guy is that busy) and for conversation purposes will be insulating and finishing the interior on my own.
Thank you in advance for any advice you may provide!
- 28x36x10'
- 2 ft overhangs all the way around
- 1-10x8 insulated garage door
- 2-36" walk doors
- 4-36x36 windows
- wainscot on all sides
- house wrap under steel
- laminated posts
