What are box wrenches for?
71goldss
Northern Calif
I have a few of them that came with my Echo blower and trimmers for removing the spark plugs. I'm curious what plumbers use them for?
edit; Never mind. Just read post #2
6erWebb
Franklin, Tn.
As above with the plumbers tools. I know most if not all bmws have them in the tool kit in the trunk for spark plugs also.
383novamike
Midwest
I have one in my snowmobile tool kit for spark plugs.Stick a screw driver through the holes for leverage.
Danglerb
SoCal
Weird, this is what I found looking at the part number associated with the picture.
Stahlwille 43320607 6mm x 7mm, 10750 series, Box spanner.
I don't see that being used in plumbing or sparkplugs.
Skin
Boston
that's the most common application but if someone makes them in all sizes that wouldn't surprise me. They're cheap stamped things and as stated often stuck in tool kits.
6/7 could be handy for a bicycle or ATV kit.
Provincial
Near Salem, OR
This form of stamped tool was the basis of the first socket wrenches, using a square or hex drive for the detachable handle.
lbgradwell
Oakville, ON
AndyA
Texas Near Dallas
I thought they were just cheap subsitutes for a good machined/broached socket. Same uses. Sometimes it's just about the $$$$.
marlinspike
Virginia
Ah, very interesting, so basically it's for when a deep socket won't work, but a deeeeeeeeeeeeeeeeep one will.
jmm
NC
Where I work, they're just very deep sockets. Most common used is 30/32 mm for turning nuts on a VERY long spindle.
Jbullfrog
Avoca, Iowa
Plumbers don't like ratchets and socket because they usually work in wet dirty places. These are easier to clean and can be kept together on a big ring for transport.
Skin
Boston
Yes working under a 10yo car fresh off the slushy/sand and salt ridden roads is a perfect picture of cleanliness :p
cheechi
Triad, NC
I have often wondered why there isn't a standardized 'cleanup' prep routine when working on say steering, suspension, or when you need to get to things under/near the dirtiest parts of a vehicle.
I understand the need to see the mess, where drips and leaks are coming from and all that, but after you've taken a light and observed it, it just seems to me that something like a shower with a low powered pressure washer would be the norm.
Danglerb
SoCal
If you look at the picture of the Stahlwillie tool it is not just stamped metal, the socket portions look much thicker to me.
I know guys who steam clean the underside before working on their cars, and others who dive right into the muck.
