So, probably no likely hood I would use them, even on an older car?
Ah ok.
Thanks very much guys! big help.
part of the reason I ask is because I have a Plvmb 31/32 and a Bonney 21/32. But, interestingly, I found a Craftsman 21/32 date code G, which is considerably newer.
p.s. by "older" I mean mid-60's and prior
Ah ok.
but by no means, do you get rid of them, for god sakes, they are tools, they was put on this earth to hoard
Ah ok.
craftsman still makes 25/32, 21/32 and 19/32- 1/2" drive sockets.....
Right, Craftsman still offers those three sockets (12 point, standard depth) but back in the day I think Craftsman also offered 12 point 1/2" drive deep versions in the same sizes.
Jim C.
The only deep sizes I've seen in 32nds are the 7/32, 9/32, 11/32, and 25/32" sockets. The 19/32 and 21/32 deep sizes aren't listed in the 1960 catalog.
Jake, are you sure? I coulda swore Craftsman offered all three as deep sockets at one time. I could be wrong, which wouldn't be the first time.....or the last.![]()
I can only attest to the sockets offered during the =V= period and newer. BUT, if the 19/32 and 21/32 deep sockets were offered during that time - I WANT THEM.![]()
Used on fine tread fasteners. Willy's put a ton of them on the truck in my avatar. Glad I kept them from sets I had gotten.
Coarse 5/16" bolt = 1/2 wrench; Fine = 17/32
Coarse 3/8" bolt = 9/16 wrench; Fine = 19/32
Etc.
Took me a while to figure out the pattern.
First of all, nice truck!
I have never heard of the head/wrench size of an NF hex bolt being different than the head/wrench size of an NC hex bolt. Are you saying that the heads on your fine thread 3/8" bolts are slightly (by 1/32", per your theory) wider than the heads on your coarse thread 3/8" bolts? Have you miced the head diameter on the bolts you're referring to? Or does the 19/32 just feel like it fits better?
This is not a challenge. I am officially intrigued.
I did not mic the bolts but have put a wrench on and had wiggle. Went to the corresponding x/32 wrench, and no wiggle. These are fasteners in good shape, not rusted to ****. The carb mounting bolts come to mind first....17/32.
Jim C.
They do exist.
Normally 3/8 hardware uses 11/16 (.688") nuts. 11/16 wrenches were way too big on the nuts in the toe clamp kit. .....out came calipers and they are 21/32 (.656"),.....
Yes, in 1962, rebuilding my first car, a 1930 Model A Deluxe Coupe, that's the first time and place I found a need for that socket.21/32” socket was designated for Ford Model A and B connecting rods
Mostly because they're 100-years old and 1/2" drive was the standard of the industry up until recently (by my standards) Literally everyone bought 1/2" drive and the better sets had every size socket from 3/8" to 1-3/8".Mostly you will see the oddball /32 sizes in 1/2 drive for some reason.
