Spike00513
- Joined
- Jul 18, 2012
- Messages
- 47
I'm looking at buying a pressure tester and vacuum filler, for automotive use
the pressure tester is to pressurize the system maybe up to around 20psi with a hand pump, as you may know
to help find leaks
and vacuum filler, using shop air to quickly refill a cooling system with coolant after emptying it to perform repair work, such as replacing a water pump or radiator.
Does anyone know what's best to buy?
I noticed Matco, Mac, Snap-On, Cornwell, and even Harbor Freight now all appear to use the same design pressure tester. Maybe it's sourced from the same manufacturer; I don't know the name.
However, Cornwell tells me (at higher new price I bet) that theirs has 1 year warranty only, not lifetime as you get with hand tools.
Hopefully it's a simple enough design and rebuildable.
I wonder what the other truck brands are; I plan to ask.
Meanwhile, Harbor Freight's is only 90 day warranty, though the cashier said he's never seen one get returned, implying good working quality.
But vacuum filler, I'm unsure what to buy. Obviously there's a price difference when you compare say Snap-On to Harbor Freight, or Schwaben from ECS that I hear fails after 6mo.
Again, unsure of warranties.
They also seem different in design.
Some screw into the cooling reservoir for example with a stant-style cap; some people say that design is better, others say it doesn't matter.
Whereas the other design uses a rubber cone that seals up when you push it on and start vacuuming.
Probably two must-have tools these days to do any sort of work relating to cooling systems, a big part of a car that tends to have issues after 100k miles. Or even just regular maintenance cooling flushes.
Curious to know what everyone thinks
to help find leaks
