What are these connectors called?
North Run Grader
Swan Hills, Alberta
https://www.alibaba.com/product-detail/12V-DC-Cigarette-Lighter-plug-cord_60441489941.html
Specifically this -
showimage.html
I have a cb radio for my Jeep Wrangler and occasionally I use my motorola 2 way radio when scouting new roads or locating new work locations. I have the 2 seperate antennas hard mounted and a design for the hard radio mounts in mind. I prefer only hard wire 1 power cable as I will never actually have to use both radios at the same time. If I can find the name of the connector I can order a set to solder on the cb. Space is a premium in the 2 door and I'm trying hard to maintain the factory appearance.
Ok, the 6th picture is what I'm looking for, but the other end. I actually have a few of these cigarette power cords but no spares of the other end.
calmac
Try "SAE connector" and see if that's what you're looking for. I can't see the pic either.
LS6 Tommy
Northern NJ
Make sure an SAE cable can support the current draw of your radios. My Connex uses fused #8 wire direct from the battery...
Tommy
kbs2244
Those connectors are designed for semi-permanent installs.
Not really for multiple connect/disconnect use.
I would try and come up with some kind of switch or just run 2 hot wires.
They are not all that big and the radios have on/off switches.
