What are these craftsman tool for?!
Jbullfrog
Avoca, Iowa
The left is an L handle and the right is a square drive extension. The early ratchets had a square hole and had to be flipped over to reverse. They came with a short square stock insert with 2 detent balls (one for the ratchet and the other for the socket.
The L handle was an early socket accessory too.
J
jmlcolorado
Elbert County, CO
Really? Is this a test?
Nope. Not a test. I've never seen these before and wasn't sure if there was a special use.
Good info! I wasn't aware early ratchets has female holes.
Thanks!
First pic looks like a u-joint extension.
It is a u-joint, but I've never seen one with two female drives.
Two Door
Houston, TX - USA
Am I correct in assuming you use the L-Handle like you would an allen wrench, i.e. with either a short or long handle, depending on how much leverage you need?
rick carpenter
Huntsville, East Texas
Well yours may be an L-handle but my 1/2" drive 06789-W-2 turned out to be an R-handle! :evil: I think mine's Plomb WWII gubmint-issue because the number is a WWII gubmint number and the batch of tools I bought it in had several other Plomb tools and a WWII Snap-On gubmint-issue ratchet.
Mine was missing the ball in the detent on the straight leg, so I ground that square drive round, filled the hole, and dipped it in Plasti-Dip. Got it back in '13 and I haven't used it yet, but to paraphrase Milton, it also serves which only sits and waits.
