What are these NUTS called ?
John Timmins
Flagler Beach, FL
I restore Mercury outboards with automatic transmissions - 1957-1962. A guy who worked at Mercury 42 years said Kiekhaefer stormed through the plant one day screaming that his outboards were NOT going to be glued together with Locktite etc. Below are two locking nuts found on Mercury outboards of that era. They are probably on many other Mercury outboards, but I can't say. I only work on these models.
The nut with the rectangular shaped stamp has this shape stamped in 3 of the 6 flats. They are on the power head studs for securing the power head to the drive shaft housing.
The other nut has the ends of 3 flats "pinched". These are on the power head casing bolts which bolt the block and block cover together along the crankshaft centerline.
1. What are these nuts called if I order some NEW ones ?
2. Are these aircraft nuts that are supposed to be used only once ?
I have a crankcase that has some issues with sealing....leaky crankcase. I sealed the crankcase with Locktite 518, but I did not use these locking style nuts. I believe that driving down the road may have loosened my stainless steel nuts and bolts which then out the sealing Locktite 518 - my own fault of course.....:eek:. Tightening up the crankcase nuts and bolts beyond the recommended torque didn't seal my crankcse, so surgery #again# for my 1962 Mercury 25 H.P. Merc 250 Super Hurricane . :eek:
sublimate
Colorado
Toplock nuts - distorted thread at one end
Centerlock nuts - distorted thread in the middle
J
John Timmins
Flagler Beach, FL
A Mercury factory guy told me they are called Distorted-thread hex locknuts !
Castle Nuts...aren't they Castellated nuts ? Harden them up and pass a cotter pin through the "castles " ?
rlitman
Long Island
This. They work like a nyloc nut. All locking nuts are supposed to be single use... Can they be re-used. Maybe.
castle nuts, but they usually have more groves
Nope. Castellated nuts have a groove. These are just deformed enough to lock onto the threads.
On another note, loctite may not work so well on stainless. There is a special activator for just that purpose.
fsae0607
San Fernando Valley, CA
Locking nuts can usually be re-used up to five times. This seems to be industry standard, based on aerospace fastener specs that we use at my work.
In my experience qualifying locking fasteners at my work, five cycles seems to be the minimum. We also make fasteners designed to hold their prevailing torque for up to 250 cycles!
stage20
pcola FL
"stover" nuts or sometimes called "all metal " locknuts will work as well.
this type the whole nut is distorted.
use them for high heat applications where nylon will melt.
toplessHO
central florida
in a pinch Ive made my own
center punch to middle while in a vise
chisel to end of nut cut in an X
neither will be as good as the factory ones
LXCam
It's a distorted thread nut. You can get them at McMasterCarr and depending upon what size and how many you need, I have a pretty damn good selection of SAE stuff. If I have them, your welcome to them.
Also if you have issues like this with other assemblies that the nuts just won't stay tight or if your stud or bolt/nut combo expand so much it causes it to leak, look up Nordloc Lock washes.....that'll solve any problem you'll ever come across.
justme-
Boston suburbs
You can get these from any good hardware supplier - a good hardware store with a pick-a-nut section will have them and can get in the sizes you need. Very common on power equipment - in fact we have a bag of about 200 on a shelf in the shop in the most common size we use.
Dennis Leigh Henry
South Central, IN USA
These are classic lock nuts with physical locking features~distortion. I'll have to see if I can find my old reference book that specs those features out to see what the industry calls them. They do have standards around them for manufacturing, retentive torque, etc. When I worked at Gunite I was responsible for supplier quality and I went to many nut manufacturers including several that made the lock nuts for drum/hub, drum/spoke wheel, rotor/hub, rotor/spoke wheel fastening.
Dennis
GYPSY400
Naughton Ontario
LS6 Tommy
Northern NJ
Nope. Castellated nuts are not lock nuts. they are used with cotter pins, like on front wheel bearings. The OP has Deformed Thread nuts. Snapper used them on lots of stuff...
Tommy
rlitman
Long Island
Sublimate got, but are those specific thread distorted nuts needed, or would some other locking means including Loc-tite as good?
As said above, distorted thread nuts still work at high temperature. Nyloc (and at higher temperatures Loc-tite) fail when hot.
Dennis Leigh Henry
Tommy
Yes Tommy, classic is the cotter pin style.
In aero (and other safety critical industries) .. they are also used with lock wire.. Photo shows some recommendations from http://byrongliding.com/technical/lockwiring/
Dennis
BeachBoy
We use a LOT of Nordloc at work (large hydro turbines/generator), and they are perfect, but $$$ :)
LXCam
I can only imagine what they cost for larrge ones. I'll only need 10mm and smaller for my needs and they ain't cheap.
Modern Jess
Bay Area, California
I'll second this. Nordloc ended up solving a difficult problem I was having with the exhaust header on one of my scooters (the racing bike, natch). Nothing else worked, and the nuts kept backing off. NyLocs obviously won't work on an exhaust header. Nordloc did the trick.
Zrexxer
Pflugerville, TX
OK, now that the original question's been answered a dozen times (not all of which were correct!) let's see some pictures of these old outboards you work on. I love the styling of the motors from that era.
