What are these sockets used for?
Idlem
I have 3 of these Proto sockets, what are the fasteners called that they are used on?
48548
Phoenix
Clutch head. My 51 chevy uses them for the fuse panel cover on the firewall.
Motorhead67
As mentioned earlier, clutch drive for fasteners used for public restroom partitions etc..
LXCam
Well just in case no one has mentioned it yet, those are clutch head drivers.
:lol:
KnurledNut
n/a
There are two types, A and G (newer).
KnurledNut
n/a
I know they look like clutch heads, but those screws are tamper proof straight heads. Most partitions now come with the tamperproof torx head.
Also known as "one-way screws". They make screwdrivers for removal. They have two hardened prongs that dig into the tamper resistant "ramps".
The tamperproof torx you refer to are likely a TP-27.
^ In addition to those applications listed above, older Holley 4150-type four-barrels used them to attach the metering plates to the main body, which is why I have one in my old 3/8" drive socket set.
Unless I'm mistaken, these were the most popular sizes in 3/8" drive:
(snippet from 1972 Indestro catalog. no idea what Proto part numbers would be.)
RBFD415
Love the fact that 1 style couldn't stand the test of time, we had to improve it, and sell more screwdrivers.
davethorik said:
I have a couple clutch head screwdrivers, iirc both Proto yellow handles. Didnt know there were sockets too.
^ Not hard to understand why they were made as 3/8" drive socket attachments if you've ever tried to remove one of those metering plates from an old Holley with a lot of miles on it - you'd swear the things were welded on!
joe_padavano
Northern VA
stage20
pcola FL
those one way tamper proof tools have never worked for me. ive always grinded a slot and impacted them out with a flat head.
that clutch is old school. why didnt they survive? grab better than a phillips most of the time. and look better, IMO.
wafrederick
Holton,Mi
Clutch drives were used in mobile homes too.Anything clutch drive is getting very hard to find these days.I have a few,a couple NOS Indestro and one Stanley Clutch drive screwdrivers and one of those Proto clutch drive sockets.Not ever getting rid of them.
MikeF2316
Thornhill, ON
I've found those cheap kits of 1,000,000 (ok, slight exaggeration) screwdriver bits have them. But, of course nobody knows how good they are...
ttpete
Dearborn, MI
Clutch screw heads were one of the first to be designed for power installation. Better systems later came out including Allen, Robertson, and Torx.
BDT/NWMN
Erskine, Mn
For the next question; were those systems really an improvement? :D
Heck, I could vote for any of them..
bcexplorer
British Columbia
Funny how things work, on saturday i found a clutch drive proto screwdriver at the restore for 50 cents. Remember seeing the screws somewhere but couldnt remember. Never got around to googling it before i saw this. LOL.
cliftonbros89
Missouri
Clutch heads were also used on the older two cylinder John Deere's on the sheet metal.
Yeah. I've seen a lot of them on the JD's. Worked on a lot of 2 cylinders. I have a Snap On clutch socket and a Wilde clutch screwdriver that I've used on them several times. Doesn't scar up as bad as a regular wrench or socket after a fresh paint job.
wafrederick
Holton,Mi
Matco used to carry the bits,discontinued them.Those two NOS Indestros I have came from a closed down Carquest auto parts store.
Milton Shaw
My dad had a GMC step van that used those almost everywhere on the body of the van. He bought several of the screwdrivers so he could find one to tighten them up as the van vibrated so much they would work loose.
enrare
This is a tamper-proof screw:
[/QUOTE]
How do you remove these type of screws? The previous homeowner of my house had a security screen door installed on the front of the house and these one-way screws were ussed for the installation. I'm needing to remove the security screen door so I can install a new front door. Is there a special tool for removing one-way security screws?? :dunno:
