What are these supports?
dae06
S.E. Minnesota
I am referring to the angled supports next to the fellow near the ceiling. I want to tin and insulate the ceiling and insulate and finish the walls. How can this be made to look nice with these angles supports there, and why don't I see these on anyone else's shed? :confused:
[/URL][/IMG]
-Brent-
Utah
The simple answer is, they've been proven to be ineffective in studies. And, in some real-life cases, they have shown to be detrimental to the structure due to transferring loads, such as a "vertical load" like snow. The loads transferred could be higher than what the truss was designed for (for example, due to wind) or the load could stress/displace the column.
I've seen framers use them temporarily during framing and remove them when the structure is sheathed.
73RR
Blank Email
Central Ory-Gun
As mentioned, check the plans. The trusses were designed for your particular weather conditions and, hopefully, reviewed by your local building inspectors for compliance.
D
dae06
S.E. Minnesota
Just because I like your answer, I'm going to believe you 100% and will most likely take them down....... Unless someone else can scare me enough not to.:eek:
-Brent-
Utah
Looks like there is a carpenter in that picture...what did HE say?
What's on the engineered plans?
Ard's comment is what I would do first. 100%.
I'm a guy that's been around and built stuff BUT I don't work for that business/builder or pay your insurance. Get some education on why they did that, first.
D
dae06
S.E. Minnesota
I just got off the phone with Menard's. They said I should keep them on until I plan to finish the ceiling. These knee braces will no longer be needed once the ceiling is finished.
That's good news to me :rocker:.
