What are these things?
454ragtop
Carver, MA
At least 2, and probably all 3 of the puller tools are for auto AC clutches, one removes the outer plate, other pushes it back on, third is maybe for the shaft seal? Those plier/crimpers I've seen before, but can't remember where.
HTH, Jim
On edit, those crimpers may be for bending choke linkage rods on vehicles with divorced chokes.
hayhauler71
MN
HTH, Jim
agreed on ac compressor tools [all 4]. pliers not for sure do they have a number on them
vssjim
McLean Va.
the tool at the very top is to remove and install the two part stop collar / ring on a armature of a starter when changing the starter drive on GM older style starters
Lisle brand tool
the two other puller pushers are for GM AC clutch plates left is puller only where right one is to remove and instal
lMaster Cool brand sold by many under own name but not marked
the screwdriver bit looks like is went to a valve adjuster tool but you need the other part
tee handle and pliers I don't know
