What are these things
Nothing
North Carolina
I just built a new house and I’m getting really excited to do the epoxy coating. While the temp isn’t in the right range, I’ve been walking around in the garage & getting my ideas together.
I have expansion joints around the entire edge of my new garage floor filled with some kind of soft, flakey material. I know back in the day they used wood. Don’t know what the new material is. I also have a foam barrier between the garage slab and the slab poured for the house. Pics will be attached.
The whole garage has this 4-6” lip running around it as well and I thought that if I put a paintable vinyl covebase around it it would also give me a way to cover the expansion joints?
What options do I have? Anyone else run into problems like this? I know that expansion material isn’t paintable but what solution do I have to resolve this?
In the last pic you can see that the foam is soft enough to cut.
Thanks
NUTTSGT
Northern Central Ohio
Looking at the pictures on my phone, it appears to be celotex. A fiber board that has been used for years, more like decades for expansion joints. Celotex was a brand name for a cellulose board. I believe it has has some kind of asphalt impregnation in it.
I'd cut it down and fill the gap with something like Sikaflex.
driftpin
Pic #1 shows a wood partition wall, and the foam insulation and the fiber/asphalt expansion joint, yes? You are trying to decide what/how to cover the area from the garage concrete pour to the wall? What about an L-shaped piece of steel, fastened to the wall baseplate for the short-side of the L-shaped piece of steel, and letting the long side 'float?' You could use some type of flexible sealant on the L-long side, underneath, to prevent water migration.
Taking a closer look after posting the above, I now see that the partition wall is built upon some masonry construction, <1 ft high? And the narrow expansion joint is at the end of the slab, between the concrete and the concrete for the house? So, it's a floating slab? In that case I agree with NuttsGT, use a narrow oscillating tool to remove about 1/4" of the top of the expansion joint and fill the made-groove with Sikaflex.
burleyfarm
Northern Michigan
What NUTTSGT said.
N
Nothing
North Carolina
Thank you. I have been distracted with closing and moving and kind of forgot about this post.
Thanks to everyone who answered.
