What are these tools?
oknope
Canada
I inherited tools from an auto mechanic. Identified most of the stuff I didn't know from model numbers but these ones don't have any apparent model numbers that I could look up and I don't know what they are called. Can you help?
The 3.5" long 3/16" diameter metal rod looks unremarkable but was worth engraving their name onto.
Thanks in advance!
Bubba Fett
Eastern NC
The plumb bob might have been used for manual alignments. Some sort of puller at the bottom. Looks like some old hose clamp pliers up top. Nor sure about the pliers with the black handles. Edit: The tool on the right is a pair of piston ring expander pliers.
O
oknope
Canada
Solved: plumb bob, piston ring expander pliers, spring compressor, wire drill brushes, wire terminal removal tool, CV boot clamp pliers. Thanks all!
O
oknope
Canada
Those could very well be hog ring pliers... seems to be lots of different styles of them. The rusty ones beside them could be as well, they almost look homemade they are so basic.
The black pliers have sharp little spikes protruding towards each other at the ends, can't really see it in the pictures. Here are a couple zoomed pictures.
O
oknope
Canada
Thanks all! Zoom in on the last pliers. They have very sharp little points in there...
RPH
Michigan Thumb
Four cycle’s not a clue item may be a pair of brake cable pliers. Designed to sheath back during installation and removal.
Fedwrench
Valley of the sun
Thanks in advance!
The 3.5 long 3/16 diameter rod is inserted into a Breaker Bar handle with a similar sized hole in it makin it a Tee Handle.
O
oknope
Canada
Wow you guys solved them all! Since you're totally acing it, I scraped the bottom of the tool chest and dug up a couple more unknown bits and pieces...
The Cobbler
1; crowfoot spanner
2: brake tool for removing clips that hold springs in place
3: pulling plug wires?
4: oil filter wrench
5: clamp to hols a lamp to workbench
5: tool from a kit with a screwdriver
6: tire valve tool
O
oknope
Canada
1; crowfoot spanner
6: tire valve tool
Well that was quick! Not so sure about the first one, but you nailed the others. :)
I got a desk lamp bracket that looks just like it, except mine base one more piece. A true multi tool.
Fedwrench
Valley of the sun
Number 1 isn't a crowfoot spanner. It's a tool for tightening alternator belts. The hooked portion grabs the alternator and the drive tool or breaker bar goes in the star shaped hole. apply pressure, moving alternator, tightening belt.
#5 is a cheap spark plug socket :beer:
Bubba Fett
Eastern NC
I remember seeing a lot of tools like this in my Uncle's shop. He was a mechanic, and a very good one. I don't know what they all are for, but I appreciate them just the same, and I've learned something, so thanks for posting.
O
oknope
Canada
OK, let's see how smart people on this forum are.
First one is by Sunnen. Second is two similar zippered cases that are 4' wide and have ~8" slat at the top - what are they for?
