What are they?
1982fxr
Phoenix
Came with some random machinist stuff
larry_g
oregon
Probably not a tool. Looks a bit like a cushion for a hydraulic cylinder.
lg
no neat sig line
RoninB4
Under My House
Doesn't look like anything I would need in a machine shop. Might be something the machinist did a nice job on and they were "trophies". Most machinists have odd pieces in the tool box over the years for a variety of reasons.
Might have been spares on a repeat job. Having a couple of spares in your tool box that helped production get back up and running is a good thing.
Also, I would often make 12 of something when I only had to make 10 in case I f*cked up one or two. The extras, even though now scrap, would be used for set-up of further operations. Can't ruin something further that's already ruined but can test whether the set-up will produce good parts for the remaining batch.
driftpin
Steve's guess makes me think of yes, alignment pins of a vehicle having body-on-frame construction, when mating the two, at points of attachment. Set the rubber with steel sleeve biscuit in-place. Insert the alignment pin. lower the body onto the pin. Remove pin, insert fastener.
Don't body shops use those for measuring distances between points on a frame, where holes are made, for 'pulling' frames?
quickfarms
Southern California
An alignment pin would not need those holes around the base, they look like they are for lubrication.
any idea on what the machinest did or worked on?
