What brand orbital is this?
climb.on
Minnesota
Going through a pile of air tools I picked up at auction and trying to determine what's worth keeping and in this case fixing. The bearings are mangled. I just don't even know what brand it is to start looking for parts. Any ideas?
dnschmidt
Phoenix, AZ
From the paddle it looks like a very early model Hutchins but Hutchins identifies their sanders so it should say so somewhere on the tool.
C
climb.on
Minnesota
Can't help you on the brand, but likely the bearings are standard and readily available
That's really the more important issue I guess. The bearing/retainer issue can be seen in the last pic. Is that supposed to be a sealed bearing and it just came apart?
C
climb.on
Minnesota
This is the part I need to replace. Ball bearing are missing and shielding is mangled/gone. Definitely, not a standard bearing on a shaft. The shaft acts as the inner race of a double row of ball bearings. I don't see anything like this available, but I might not be looking in the right place. Chime in if you can help, or this one is garbage.
