What Caulk For Concrete Walls?
Dynasty
USA
My house has poured concrete walls as the foundation. The house is 11 years old as has minor cracking on the above grade portion of the walls. I would like to seal them, but would like to know what the proper caulk is for a quick job like this? I'm looking for a specific make and model please. Thank you.
Daubs
Eastern Nebraska
My brother is a school teacher, and paints houses in the summers. He swears by Vulkem.
I have used Vulkem on cracks in my poured concrete foundation walls. Works well.
Hilltopmasonry
Do you have a picture of these cracks? If they are cracks where water could potential he be going through then you might want to use an epoxy injection system.
If they are minor hairline cracks that don’t go all the way through then I would probably use polyurethane sealant. Any of the brands are fine to use. Just pick the color that is close to your foundation
D
Dynasty
USA
They are minor hairline cracks that don't go through. I will post some pictures later on.
ConCretin
Central Maine
Based on your description, I'm not sure I'd do anything. If you feel the cracks need to be sealed, I'd mimic some previous suggestions and go with a polyurethane sealant such as Sonneborn NP-1 or Sikaflex 1a. Limestone best matches the color of concrete.
If you want to do it right, chase the cracks with a grinder and a crack chaser disc and fill the resulting groove rather than just applying the sealant on the surface, It will look and perform better. Install a backer rod in the bottom of the groove for the best joint design.
ConCretin
Central Maine
Looks like a typical shrinkage crack. Unless you are getting water through it, I'd leave it be. You'll never improve the aesthetics and it's not a structural issue.
rlitman
Long Island
The pictured crack is pretty thin, and chasing and filling with polyurethane caulk will look awful. If that's a poured foundation with a cast surface, I'd use my finger to press in a hydraulic cement. This can be mixed into a putty consistency, and if you're careful enough, you can just make that crack disappear. So long as the crack isn't active, it'll be fine.
If the crack is still expanding, then yeah, you'll need to chase it. But if you think it is moving, you can monitor it with something like this:
https://www.humboldtmfg.com/concrete-crack-monitor-crack-gauge.html
