I'm in the market for a new compressor. I currently have a single stage 3 HP Husky rated at 10.2 CFM at 90 psi. It's adequate but I could use a little more air for sustained blasting. I'd like a 2 stage and a little more air. I also need to move the compressor to a new location (second floor of shed) and would prefer to do this lift only once so it may be time for a new compressor. I have a 12x24 aftercooler, Norgren filters, and Solberg intake silencer and filter I would move to the new compressor.
I was pretty much set on the HF 60 gal, 2 stage, 5 HP, 15.8 CFM, which is a rebadged BelAire 216V (https://www.harborfreight.com/5-hp-60-gallon-165-psi-two-stage-air-compressor-93274.html). This unit has an inline Italian pump and generally seems to have good reviews. Regular price $800, I've been waiting for it to go on sale for $750 which it does from time to time.
I've recently saw at Lowes they have an 80 gal, 2 stage, 5 HP, 15.8 CFM unit for $900, which is a rebadged Campbell Hausfield HS5180 (https://www.lowes.com/pd/Kobalt-80-Gallon-Electric-Vertical-Air-Compressor/1000528985). This unit has a V twin Chinese pump that I haven't found any info about performance, longevity, etc.
Lowes also has a 60 gal, 2 stage, 3.7 HP, 11 CFM unit (https://www.lowes.com/pd/Kobalt-60-Gallon-Electric-Vertical-Air-Compressor/1000542193). This has the same pump as the 8 gal 5 HP Lowes compressor, just spins it slower with a smaller motor on a smaller tank. Down the road I could change the motor for a 5 HP and spin the pump faster for 15.8 CFM.
Vibration is a consideration as this will be mounted on the second floor rather than on a pad. I'm not sure the merits of inline vs v-twin pumps but I'd imagine v-twin has the potential for better cooling. Whether that matter given my aftercooler I don't know. Chinese pump vs Italian pump also concerns me. Though the IR compressors I saw at Tractor Supply all have Chinese pumps and sell for significantly more than any of these. What do you guys think of these compressors or any others I haven't mentioned? What would you get in my situation?
