What connector for welders, etc?
mrb
When building a garage or shop, what is the 220v connector commonly installed for welders, plasma cutters, etc? 30amp or 50amp? Or both? 3 wire or 4 wire?
thanks
BigChevy80
Illinois
thanks
You'll have to determine what the rated input of each device is. Usually printed somewhere on a tag or sticker. Also look at the type of electrical plug that it has.
For a 50 amp circuit like most stick welders require, you'll want to use a NEMA 6-50 like this: http://www.debmark.com/Kilns/Evenheat/images/650R.gif
Most 220V MIG welders and plasma cutters require 30 amps, so you would want a NEMA 6-30 like this: http://www.iap-home.com/images/products/3707.jpg
For stuff like this you'll only need a 3 wire circuit (2 hots + 1 ground).
timgr
Medford, MA USA
Also, it may be cheaper to fit fewer outlets in your shop and then buy an extension cord. http://store.cyberweld.com/230voexco25.html Buying cable for dedicated 50A outlets around the shop will get expensive.
You can also run a 30A device from a 50A outlet with a simple adapter - but obviously not the reverse - so a 50A outlet plus an extension cord tailored to the device makes sense to me.
mrb
thanks for everybodys input. I am making a big connector order and I was going to get some of the connectors used for welders to have on the shelf for future use. Wanted to make sure I got the right ones.
bmwguru
My Lincoln MIG uses the 6-50. I have been slowly converting my other 220 toys to the 6-50 plug style. I made an extension cord that will fit all of them, so it's simple and convenient.
