Yup, I'm getting a clue now.
I'm out of the auto-repair industry in large part because of this. Folks with fancy cars refusing repairs 'cause "it costs too much". The thinking is that it's better to spend WAY more money on "new, with a warranty" than take a risk on the vehicle they already own, which they've already depreciated.
Most--not all--leakdown testers have two gauges, with the orifice in-between. My first leakdown tester was a Snap-On MT324, single-gauge tester. Orifice is after the regulator, but ahead of the single gauge. I bought this around 1988-ish, I think.
Later I bought an automotive and aircraft-suitable two-gauge unit, in part because it had the standardized, FAA-approved .040 orifice, but also because the Master Orifice for Teledyne-Continental engines seemed like a wise thing--the Master Orifice allows you to "calibrate your expectations" upon each use. I STRONGLY recommend the ATS 2EM.
ATS PRO DIFFERENTIAL PRESSURE TESTER WITH MASTER ORIFICE - Our own ATS brand Differential Cylinder Pressure Tester combines the features of our popular 2E tester and a Master Orifice into one tool.
www.aircraft-tool.com
Most folks will want to tell them to include the 14mm adapter instead of the 18mm it normally ships with. (Or buy a bunch of different adapters...)
Although for my purposes--strictly automotive and generally higher-performance applications--the Master Orifice is too generous with the leakage. I accept about 2/3 of what the Master Orifice/Continental shows as acceptable.
Or a cylinder-balance test. Either way, you're looking for one or more cylinders that don't measure-up to the rest.
The INDICATED leakage has as much to do with the leakdown tester orifice (NOT the "Master Orifice") as the actual leakage. Which is why the Master Orifice is so helpful, especially to folks who aren't used to their leakdown tester.
Listen at the exhaust pipe. You hear noise, it's a leaking exhaust valve.
Listen at the throttle body, with the throttle open somewhat. You hear noise, it's a leaking intake valve.
Look in the radiator or surge tank. You see bubbles/turbulence, you've got a compression leak into the cooling system--head gasket or cracked casting.
LASTLY, listen at the oil-fill cap. You WILL hear noise, and that's the point where you need the gauges. IF the leakdown percentage is acceptable--AND THAT VARIES WITH THE SIZE OF THE ORIFICE, and can be confirmed with the Master Orifice, if the tool is equipped--you're good to go in terms of ring leakage. If the gauges show excessive leakage, you've got piston/ring/cylinder wall problems and either you drop a bore-scope into the cylinder or the heads are coming off for inspection.
Overhead cam engine is compression- or leakdown-
tested no differently than a flathead, or a pushrod engine. Nothing different at all.
