twentythreemx
Hello - I bought a HF blast cabinet without doing much research and didn't realize the importance of CFM with air tools until now, whoops.
Keep in mind it's a new unit, maybe something withe gun is bad? But it wont siphon up any media. I'm convinced it's my compressor.. Its only a 35 galllon and is like 6.4cfm at 90 psi and the cabinet says it requires 9.8 cfm at 90psi.
So I thought maybe I can hook up my smaller 13 gallon compressor in parallel with it. Reading a few threads about it, seems common, and if I add CFM from each of them, I'd be right where I need to be.
Well I tried, and failed, and it's still barley trying to **** anything up the media hose. I can get a little to come out sometimes if I press the tip up against an object..
I saw a lot of different methods of hooking up the 2, and have no idea what's right or wrong. So here is what I did do, can someone plese tell me where I maybe went wrong?
Compressor 1, 35 gallon larger unit: ran normal output line to a T. The T goes into a water separator/filter, the other side of the T goes into compressor 2, the smaller one connected to normal output.
regulators turned fully at 100% on both compressors. The output of the water filter then goes to the blast cabinet, where I hooked up a regulator mounted into the input of the cabinet. That way the air isn't regulated at either compressor, and is done so evenly at the cabinet itself.
Also I hooked both up to the T and did the T on the other side of the filter, so that both units are filtered air coming through.
It doesn't seem to work any better (maybe like, a teeny tiny bit) than when running off just the 1 larger compressor. I did have to use a lot of hose to do this, and all I had was 50 ft hoses, so I have a ton of hose, and some is 1/2 some is 3/8, and a lot of quick connects.
Could the 3/8 hose and quick connects be killing the volume/pressure? Or did I maybe just get a broken gun?
Or do I bite the bullet and run the 220 and get a new compressor. (I know thats probably prefered, but for a new "hobby" that really wasnt in the budget)
Any thoughts on my config? I saw some ppl say touse check valves, other ppl say it's not needed. One thing I read said to put the line coming out of the relief valve, not the regulated side... not sure what difference that would make if I open it up all the way... doesn't seem like it should be rocket science but clearly I ****.
Any help is appreciated thank you!
