what did you buy today?
yotarover
i scored a ity bity crapy CE arc welder today 70amp's 50$ (will work well for tacking or welding small ****)
Black Bull 14" chop saw 99
Black Bull 5sp bench top drill press 50
5" Makita disc sander 20bucks
HF CE easy mig 50 - can't get it to feed the wire it's the easy mig 100
OK Clarke hss drill bit set 20
and 2 25' lengths of 4"x4" square steel tubing and 1 big 8ft long by 5ft wide 1/8 steel plate 180$ <80 sumfin and some change
Y
yotarover
got this HF easy mig for cheap it ran as far as turing on and the feeder wheels turning but wotn feed the wire to the sleeve.
[/IMG]
also got this Cambel Husfield 70arc still can't get it to get stable to start a bead this thing sux
[/IMG]
got this and the black bull 14" chop saw at tractor supply sweet *** to. i didn't have any cutting oil so i used the gear oil that i use for the truck and that **** works great
[/IMG]
RbrtAWhyt
North East Georgia
On those cheap HF welders, my Dad swears by his. He said it wasn't worth a **** with the wire that came with it. He says it works flawlessly with good Hobart wire.
Y
yotarover
i picked up a small roll from lowes when i went to look at a huge as Kobalt rolling tool box (the one with the built in cd player and speaker for 400$)
it wont feed the wire into the sleeve not even grab it and unroll any idea's on how to fix the small rubber wheel?
Ditchdigger
Eugene, Oregon
Nabbed this Easco metric set for a tenner
Looks like the only one ever used was the 12mm. Some american made goodness for the price of HF.
00S4Boy
A KRL1024BPC. Should be here next week, now to see if the digicam still works.
SnowBlaZeR2
Texas
New everything but tub for the bathroom.
Some pliers I needed for my 2nd set of Cman Pros, a couple Cman combo wrenches to fill in some blanks in my trail box all from Sears.
3/8 x 100 Goodyear hose, socket trays (which I hate) and one of those Pittsburgh Pro rotating head ratchets all from HF. My wife wanted to stop in there and look for some stuff for her house tool box and I couldn't resist.
Bjkearns
wow that is so cheap
title and plates on 2 or more cars for $45
cheap cheap cheap
I need out of CA
nate379
Palmer, AK
Was just a title transfer which is $15 and then I got a set of Veterans plates which costs $30.
I'm not a "vet" per say since I am on active duty still but they went back to the ugly as **** yellow plates and the vet plates are white. Not to mention less harassment from cops and the $30 goes to a fund for vets.
bmxr4life87
Bixby Oklahoma
Got an old waterloo crinkle finish box with a few tools some american for $30 and I got an IR air drill from a coworker that needs planetary gears for free
gc11090
I have been at work all day.....
But I needed to do some tool shopping, so walked across to lowes and picked up...
kobalt tap and die set for $20
Missing 5/16th gearwrench for $7
ugapug
Warner Robins, GA
I went to the local flea market..
Got:
Snap-on orange hard handle Phillips #2 screwdriver $2
Snap-on 3/8 6 point combination wrench (old underline style) $2
Snap-on 7/16 12 point combination wrench (old underline style) $2
Snap-on 20" FX20 Ferret 3/8 extension $2
Snap-on 6" 3/8 extension $1
Snap-on black Ratcheting screwdriver $10
Craftsman 3/8 RHFT ratchet with someone's whole last name engraved in it :( $5
Local pawn shop nearby and got:
Matco USA made Metric Flare nut wrench set (NIB) $90
So yeah. I think I did ok today :)
ugapug
Warner Robins, GA
The old guy at the flea market had the Easco version of the RHFT too - I may go back next weekend and grab it too since it's essentially the exact same ratchet.
DarrenF
Thunder Bay, Ontario
A set of 0 degree Snap On wrenches in metric, a power probe 3 master set, and a mastercool 71475 hydraulic flaring tool (upgraded from my basic mastercool setup)
mrholeshot
MEMBER EMERITUS
Picked up an N-71 Snap-On ratchet at the Flea market today for 8 dollars, 13 Dasco Chisels and punches (new in packages) for 15 dollars, 3 Craftsman 3/8 breaker bars, 1 Craftsman 1/4 breaker bar and one 1/2 Craftsman breaker bar (so old its round) for 10 dollars.
Rickster
SE PA
- A set of NOS in the package Cman locking 3/8 dr extensions
- Cman autoranging multimeter
- a nice wrench rack for my cart
- Someting called a roberts (I think) pipe or water outlet remover 4 pc kit. Looks like it fits into a water outlet and then when you onscrewit, part of itself rotates out and grabs the outlet for removing. It's like a stud puller only for inside diameters.
- Handful of older Mac ind finish wrenches with owners marking -I don't know why I bought them, but they were the value items in this old box.
- An older retangular Snap-on name plate with its pins and lockng tabs in place.
trbomax
starvation lake,mi.
275 gal food grade plastic tanks. $85 5" fill,2" ball valve at drain.
Strouty
Southern Maine
I got an electric walk behind forklift, 3000 pound capacity, 106" lift. I paid $260 and it came with the charger, added some water to the cells, charged it overnight and she works pretty good. No brakes, literally, the shaft that holds the drum is snapped off. I was trying to make an elevator/dumbwaiter to get engines and other heavy things upstairs, this should get me started!
slip knot
Texas gulf coast
Picked this up along with some other goodies. I think I'm gonna try and restore it. Paid $40 for it with $100 worth of tools in it.
caper150
Mantorville MN
8 sheets of drywall, a bucket of mud to finish off the shop, hangers and end caps for the gutters on the house and two new blades and a drive belt for the mower. I might need to go get a job if this keeps up :lol_hitti
lipadj46
6 ton harbor freight jack stands. Sure they may collapse and kill me but hey they were only $30.
Hank McMauser
Payette County Idaho
I picked this up from CL for $50.00
delta 11-980 drill press
then afterwards picked this up at a Boise/Meridian pawn shop
for $100.00, I believe it's a kr-56
Tim Cowan
Piedmont,Alabama 36272
Snap-On KRA65 box with the sliding tray. All the talk here made me want one bad-like.
I have this same box. Bought it forty years ago, from a friend that his dad had a shop. It was made to hold a Snap On valve seat grinder set, for stones, guides, and stone dresser. I got it and the SO valve refacer machine, made by K.O. Lee, and some other stuff for $150. I still use it some.
crewchief888
NW indiana
had to buy a new shovel after i broke the handle on the old one digging/prying on some small stumps and roots.
yea :wtf:
:beer:
