What do I do now?
Chipmunk
I had an old KR-56 blasted with glass beads at a body shop. The guy doing the blasting covered the Snap-On emblem with duct tape and when I removed the tape this is what I found.
Some of the original paint came off with the duct tape. What can I do now? I want to keep the original emblem if possible, but I know if I tried to repaint it with small artist brushes by hand it would look like hell.
SweetD
Rhode Island
Wow that *****! I'd be pissed!
Is the lettering raised or embossed on that badge?
Maybe have a pro repaint it?
I'm looking for a vintage badge myself for my Snappy box restore...good luck!
Dave
thundermug
usa
It might cost you, but....take it to an old school pin striping artist. The kind of guy who does detailing for motorcycle fenders and such. Someone like that would be able to color match and restore it while preserving the original vintage aesthetic.
e-tek
Saskatoon, SK
Have a pro-airbrusher, or signpainter redo it - depending if you want a "smooth " or "brush-strokes" finish, respectively. I'd go with the brush-strokes look, it's more period-correct.
chris fresh
savannah ga
i would just blast it and have someone paint it,my emblem was easy to restore because of the raised letters,just painted it and then face down on some 220 grit,then clear.are your letters raised? can't tell really in the pic,but it looks pretty flat.check my resto thread in my sig,might give you an idea as to wich way to go.
steel 35
Between the PNW and the Emerald Triangle
I would take it to a sign shop if its smooth; and just have two stickers printed and you have a spare to put over it again if something happens, cheep easy and they can make it very close to identical. As for the little letter's at the bottom have your personal quotes put on.
AZ_Catskinner
Morenci, AZ
Another vote for leaving it as is. I'd probably hit it with some clear coat before installation though.
If you want it restored, your friendly neighborhood pinstriper should be able to fix you up quick.
BFBOB
Seems to me the sandblaster screwed up, and should pay for the restoration. He should have used painter's tape to protect the paint, with something thicker over it to resist the blasting.
Exceller8
Banning, CA
What an idiot! :mad: Painters tape was indeed the way to go. Tough call on what to do now but I'd probably leave it as is.
gorilla
I think that you get to wear the dunce cap for not removing it before blasting, never depend on others to do thongs right.
