Hi everyone. This is kind of a broad question and will generate many responses. This is good.
to help out, I’ll tell you who I am, what I do, and what I have. I’ll also try to explain why I “think” I need to upgrade.
any thoughts and input is appreciated.
im old, and getting older. I believe in working smarter, not harder. Daughter is independent so the bank of mom and dad has extra money to spend. By “spend” I mean that I will spend what I have to, but do not want to spend more than I need to. If that makes sense.
I buy quality if needed, and I seek to make things easier as I age. When I spend money I believe buy once cry once, and I always look at future proofing
For a real life example, I use a wall Mount tire rack. I can easily lift the tires up but prepared for future aging. I have eye hooks in the ceiling and use a simple pulley to lift the tires. I bought more pulley than I needed, future proofing and the pulleys can do double duty for recovery/tree, etc. as opposed to a cheap pulley that will handle a 60 lb tire, and having to buy more pulleys.
what do I do? I’m not an advanced mechanic at all. Tire rotations, brakes, alternators, serpentine belts/tensioners, oil changes. Blower/mower repair and maintenance.
I’ll tackle some suspension stuff from time to time.
my tools are basic. Jack/Jack stands. battery testers. All my tools are “general” meaning, standard screw driver “sets”, socket set is a basic “200 piece with spark plug socket” that every store carry’s. I have metric and standard impact sockets. Long ones and alll I’ve used is the 21mm.
I have an air wrench but I use the compressor for nailing. I do tires by hand. I have a 3/8 and 1/2 breaker. I’ve got some hammers for rotors. I e got a small bench grinder.
to be quite honest I’ve been able to do what I need to do with what I have. Tires take a bit longer by hand but I’m thinking the cordless stuff out there is really nice and handy. I’m on the Home Depot ridgid platform.
sometimes the ratchet works, sometimes I need to move things out of the way. I’m thinking it’d be nice to have a pivoting ratchet and possibly some gear driven wrenches.
my socket set is of lower quality and sometime I run out of “clicks”. Less teeth.
I use a c lamp and backing plates to compress pistons. The little ratcheting tool is cheap and would be handy.
just wondering what your recommendations for a killer basic tool setup?
wife says keep using what I got.
the right tool for the job is important but I’m at the point I want the nicest tool for the job within context of my use age.
im partial to Tekton for no real reason. They sell 6 point ratcheting wrenches. No one else seems to and supposedly it’s better?
thoughts?
thoughts?
