What do you call those screwy ratchets with a crank?
ToocoolZ28
Mid Tenn
What do you call those ratchets that have a crank handle on the end? Kind of like a right angle that you turn the crank to turn the socket. I don't know what they are called but I had occasion to use one the other day and it worked where I couldn't get anything else to work. A guy I know had one but he didn't know what it was called either.
I wouldn't expect to tighten anything very tight with it but it did work for what I needed, (clutch adjustment though big headers).
G_P
Central CT
I believe they were originally called a "sidewinder".
I've seen a stanley version at walmart.
Sent via carrier pigeon.
devoncoolman
quakertown pa
Ive got a craftsman one like that. Only use it when i have too. Its just a bit driver with a fold out handle. Not sure it has an official name.
McFarmer
One of the best things for oil pan bolts.
Never mind, I thought you had a speed wrench. Mine works like a breaker bar with a crank.
kursplat
S.Cal
mine falls into the catagory of "tools my family can get me for xmas while having no idea what i actually want".
and yes i could give them a list, but the things i would want at this point, are either expensive or used. niether a good candidate for a xmas list
edit: i keep trying to find a use for it..............
still looking
CNGsaves
KS and OK
I've seen a stanley version at Walmart.
^ ^ This . . . .sidewinder.
This "tool" will be so rarely used, no reason to buy anywhere other than WM or HF. Heck spending $30 for low quality ratchet that's never used, crazy . . . :eyecrazy:
Instead use that money to buy something useful at garage sale or CL.
devoncoolman
quakertown pa
Now that we know what the OP is referring to, please disregard my original statement. I agree with Dave. :lol_hitti
Yeah i was thinking something different also. That may have a purpose somewhere. But i would never use one. Only purpose i can see would be tight clearance applications but not with that bulky a$$ head on it.
Davefr
OR
Isn't that the truth.
You buy it thinking it'll come in real handy in tight spots but it's one tool I've never used.
Sick Puppy
Sydney
There are modern versions of those - Proxxon, Stanley and Facom/sidchrome all have versions, although the proxxon one has a 1/4" socket in the handle to enable T-handles etc to be used...
Jim C.
I have one just like CGNsaves posted above. I've NEVER found a single use for it and probably never will. The head is big and clunky and I can't think of any job where it will be the "right" tool. To the OP, I would not waste your money on this thing. Mine sat in my box for a few years and I finally got tired of it eating up valuable space. It's now hanging on a pegboard hook out in my shop collecting dust.
Jim C.
Jim C.
Jim C.
Here's mine, looking as new as it did the day I foolishly bought it.
Jim C.
bluebolt
Benton LA
Sounds like the OP actually can use this. I picked one up a few montsh ago havn't used it yet. I think a plain angle drive with no ratchet and a female drive end to hook your ratchet to might be more useful.
Jim C.
Mine is in the same condition ... bought it at Pep Boys. Looking back, it was a waste of money.
I got mine at a Harbor Freight. It was actually the first time I had ever been in a HF store and that's what I came out with. In the last five or six years since I bought that thing, I've been in a HF store at most three times, which is still more occasions than I've used the ratchet.
Jim C.
priceman1414
Midwest, USA
Sidewinder Speed Wrench
They've been around for a while. I saw an ad for them in an early 1990s issue of Hot Rod Magazine.
Other brands, such as STANLEY, sell ones called 'rotator ratchets' that are similar except they don't have the " T " on the end of the handle, you just rotate the handle.
Jim C.
I bought one of those about 15 years ago, gets used a lot more than I thought it would.
I'm not questioning your word. I've had mine for at least five years and haven't used it, or even needed it once. I do spend a lot of my free time tinkering with old Corvettes and woodworking machinery and haven't even considered using it, or found that it was the perfect tool to turn even a single, hard to reach, limited clearance fastener. So I'm just wondering what you use your's for?
Jim C.
USA Tool Supply
Midwest
We called them the old fashion name " speed ratchet ". Could not give them away. One day the manager of a " Jiffy Lube " came in to the store and bought one. Later on the same day he came back and bought all the rest of them. God bless that man !
WWIIjeep
Arizona
They've been around since the early 1950s. One version called a "Reechit" was patented in 1952.
http://www.datamp.org/patents/displayPatent.php?id=13962
And here's the actual product:
As described in the patent information, it can be turned with a cross-handle, or by 1/2" drive at the end of the handle, or simply by turning the knurled end by hand.
It has saved the day several times.
If you think of them as right-angle drives instead of as close-quarter tools, you may find more uses for them.
They're certainly too large to fit in very tight spaces, but if you ever have a space where there's little or no room to swing a wrench, or to use a socket without adding a very long extension, they may be just the ticket. Granted, modern fine-tooth ratchets allow you to operate with an inch or less of travel, but it will still be slow going. Using one of these right-angle drive tools will likely be faster and easier in such circumstances.
superautobacs
Vancouver, BC
*snip*
:+1:
When you don't have air tools around these can be the ticket. I've used mine a handful of times. It made the job a lot easier and faster.
I made a thread a couple years ago and got some positive responses from users: Rotary / Twist Ratchets - do they ever see the light of day?http://www.garagejournal.com/forum/showthread.php?t=48846&showall=1
