what do you use for batteries?
mikeselky85
New Castle, Delaware
i was wandering what you guys use to remove battery side posts, the ones that usually are a 5/16 screw. i know theres some tool made for them and i know you can also just use any 5/16 wrench. but i was just wondering what some of you guys used. i was thinkin a mac flex head ratchet wrench would be a good choice because of the 6 point design, but i know im not a big fan of mac.
Scout Driver
South Dakota
I use the 5/16 ratcheting battery wrenches. Is there a better version of these? The teeth are coarse and crude. They are too short too.
Scott
davesnothere
phoenix, az
I've got a 5/16 ratcheting battery wrench with a super long handle.
Bought off the mac truck, made by kastar.
I like the coarse crude action of it, for the specific application of battery side terminals, as opposed to a finer tooth regular ratcheting wrench. And its got a nice fat handle as well.
Vettman
Ca. Sierras
I happened to be in Kmart the other day and found this for around $5.00 bucks. It was one of the few items mfg. in the U.S.A.
Techniker
Why not just use an 8 mm socket on a 1/4" ratchet? I feel like there are a lot of places you can spend your money on in tools, but a special side terminal ratchet should not be one of them.
Just my thought,
Techniker
AZ_Catskinner
Morenci, AZ
I've always kept a battery wrench around, just because of the convenience factor. I've even got a set of those specialty battery pliers for top posts in the box, just because my high school auto shop teacher said to never use anything else.
Come to think of it, I have a dedicated Crescent wrench for equipment batteries just because of the corrosion issues from all the acidic dust.
Zrexxer
Pflugerville, TX
It's not like you'd have to be eating canned beans and noodle ramen to afford it; even the YA249 Blue Point pictured is only $12.
diesel research
gulf coast, TEXAS
1/2" socket. Then again, I like lead mil spec terminals. :D Did have a coworker arc out and burn my SO 1/2" combo wrench doing a battery, burnt a nice chunk of it off. Wish they had composite ratchets back then.
mrholeshot
MEMBER EMERITUS
Just my thought,
Techniker
Sometimes it can be too tight for a ratchet and socket. Plus the rubber handle keeps the sparks down although the neg should come off first. I like them because of convienance. I still have one given to me me when I worked in an Olds dealership back in the early 80's
scott37300
Wisconsin
Are some battery terminals 5/16" and some 8mm?
Doing some googling I see they make both sizes for battery wrenches. Just wondering where each one would be used?
