What do you use to clean your central AC coils?
honda1998civic
South texas
What do you use to clean your central AC coils? Does anyone use simple green? And to rinse it off would you lightly spray water from inside to out? Or can just spray it on outside?
JeepYJ
Regular SG is caustic to aluminum. They do make Simple Green aluminum cleaner.
I use some type of foaming coil cleaner concentrate I bought at Menards. I mix it up in a small sprayer and spray it all down. Hose it out the opposite direction that air flows through it.
*Edit
Here’s a link to the Menards product
acer66
Western North Carolina
After reading the most recent thread about that I went with ComStar Coil Safe which is pH neutral which was highly rated over at this old house but I have not used it yet.
KSJeff
Andover, Kansas
Oddly, I just did this yesterday since I had to replace a start/run cap after my AC died Saturday night (my local ACE Hardware had a 50/5uf cap in stock).
I used Purafilter 2000 19oz coil cleaner. Sprayed it from the outside in and rinsed it out from the outside in.
bwringer
Indianapolis
Agreed. Do not use Simple Green; it corrodes aluminum. Plus the whole area will smell like a urinal cake for weeks.
Since there are specific products for this task, it makes sense to use one.
fitter30
Peace Valley,mo
Plain water unless there's oil on it. Any coil cleaner that label reads cleans coil shiny or foams has sodium hydroxide ( lye) ph 13-14. Cleans the oxidation off fins just so it can start again. Cleaning the fins get thinner til with each cleaning till they lose enough strength and bend over with water pressure.
Jagmandave
Overland Park, Ks.
Mine is unfortunately right in front of the dryer outlet and gets impacted with dryer lint, so in season I use the air hose frequently to clean as much of the lint off as I can, once a year I use a coil cleaner that's supposed to be safe and then rinse it out thoroughly. Going on 10 years now and still cools the house nicely.
If I forget and turn it on early in the season, it sometimes goes thru a start/shutdown cycle.....when it does I get the air hose on it right away and get it cleaned out, then it works fine again.
mrvm
PA
On my rental property is it best to vacuum off the debris with a soft brush attachment or start with a hose inside to outside. The neighbor had a big excavation project going on that probably contributed to this mess. Appreciate any guidanceIMG_3231.jpeg
Snapped-off
Indiana
I'd vacuum parallel to the fins in that instance to get the heavy loose stuff, and then spray with water from the inside out.
rkevins
Central Arkansas
if your condenser is micro-channel use only water, there are coil cleaners for micro-channel but even a lot of HVAC companies don't use them
loganb
Omaha, NE
Couple HVAC tech's I've talked with all said just straight water, the coil cleaner isn't worth it on the exterior. I've used the coil cleaner once, rest of time is just straight water.
nbpt100
Massachusetts
I would think straight water and some compressed air, if you have it, is good enough in most cases. The dedicated Product makes it easier but in an extreme cases, like in the pic above, it may need some extra interventions. If you can open the top and do it from the inside forcing the debris out, it may be better. If only just to keep all of the dirt from the inside of the unit. Make sure you turn off the breaker.
Airforce_NavyDAD
The Region
You will need to see if the fins are split. If so you will need to open them up as best you could. I start with water and a solution of pink con-coil. Carefully. Let it do it's magic and react then flush with lots of water.
bonneyman
Desert SW
Those microchannel coils were just taking off when I exited the business. Those things **** for cleaning! I'd take the old Spine-Fin coils on the Trane's before those things.
nbpt100
Massachusetts
Those passage ways are so small I would think you would want to use something to reduce the water's surface tension so it flows better into them and rinses away better.
nbpt100
Massachusetts
I just read about those micro coils and they look like a good thing for the manufacturer but bad for the consumer. They look very easy to plug up and harder to clean.
From what I read, they do it because they can use less refrigerant.
