What do you use to clean your tools?
Blacknwhitepit
Eastern Tennessee
resize
- BWP
Skin
Boston
as far as a daily thing, i dont. Wipe them down with a rag is about the farthest i go. If i spend time tool polishing i could easily add another 2 hours onto my day. I dont know [m]any people who would be willing to do that.
the rare cleaning day i'll just use some simple green and WD40 on any bare metal.
miccontreras
I don't do it very often, but every once in a while when I'm reorganizing or cleaning, I will spray some Royal Purple Maxfilm on a shop rag and then use that to wipe down my tools. Mostly done with ratchets and wrenches, but I guess I have used it to clean hard plastic handles. Does kind of leave a coating, which you may or may not like.
Theloniousmonk
Where the tall corn grows!
Silk undies dipped in a bowl of baby tears.
Actually spray some pb blaster over evething in the drawers and let em drip dry. Wipe things down and remove buildup annually. I don't like gobs of grit buildup in my sockets, especially in the winter with sand and road sht on evething. Takes half an hour to do a quick once over. I actually make time for this.
trexdoink
Iowa
Greased Lightning on a paper towel for chrome and wd40 on a paper towel for all the rest.
canuckian
East coast of Canaaada
I just usually wipe them with a "not too dirty" rag. If there's a lot of grease or dirt that won't come off that way I put a little degreaser on the rag and that usually does the trick. A couple months ago I was moving a few things to the cart and as I was going I was wiping the tools with a cloth that I had used to apply car wax that I hadn't washed yet. What a nice shine that put on the chrome!
crewchief888
NW indiana
brake cleaner and a rag for a quick wipedown for heavy grease and oil
about once a year i pull everything out of my service truck box for a good cleaning and degreasing with mineral spirits and air dry.
especially in the wintertime i dont really clean things off real good, lot of times tools are getting snowed on.
any surface rust that does form, wipes off with a rag
:beer:
woody 73
The Great State Up North
I use a very special mix of 1 part wax and three parts thick oily fat(grease),on all my tools it keeps the rust at bay. I keep as much of this special mixture on as possible...Oh sure the tools look like **** but then I never see any rust!
cleaning tools sounds mashugana,but who am I to say otherwise:Homer:
Bull
I use LA's Totally Awesome from the Dollar Tree, works great and makes the tools look new again:bounce::thumbup:
That stuff really works? It's so darn cheap, I was skeptical. I need to refill my ultrasonic machine; I think I will try some of this stuff since it would be a lot cheaper than Simple Green or Greased Lighntin'.
Busted Bolts
NewEngland
I use ZEP 45 with teflon to clean and protect from humdity. Does a ggod job, have used WD 40 also, but found it left discoloring on my SO Black hard handles????
D9H 90V
New Mexico
WD 40 and a rag, once a week ill come in and spray everything over a drain pan and wipe it with a rag works real good, working on heavy equipment/diesel tools get super dirty
Gregg33
Port Colborne, ON, Canada
WD40 and a rag or shop towels.
I clean my rubber handled tools and my Estwing malette with silicone spray and a rag, it doesn't melt the rubber like WD40 and believe it or not it doesn't make the handles slippery (like you think the silicone would).
handyvorb
AL, USA
A clean rag.
All my tools are clean and non-rusted. A very light surface coat of oil from use (so light it doesn't come off on your hands) left by wiping down with a clean rag is self cleaning and keeps the tools from rusting.
Cleaning metal with solvents tend to make them rust.
J
JAKE-THE-TOOL-MAN
Bremerton, WA
It works WAY better then simple green, I was skeptical of it to at first but I use it on everything from cleaning my motorcycles to the tires, engine bay, and under chassis of my truck. It hasnt messed the finish up on anything
airbatica
Denatured Alcohol to degrease.... much easier on the skin than the harsher solvents. Then wipe it down with a clean rag and a little gun oil or light machine oil.
mkdive
NPB (Socal)
I will have to try the LA Awesome.....I had a bottle in my office as a matter of fact. I never thought to use it on the tools. Its a great cleaner and the price is right, but the sprayer attached to the bottle leaks. After 5-10 pumps the cleaner leaks down the lever (last two bottles I bought). Maybe a freak occurrence?
I use WD40, Simple Green, or mineral spirits depending on what is on the tool and what plastics, finishes I am trying not to damage.
90% of the time I use WD40 and a rag.
:thumbup:
dirtrider
For old tools that are really rusty or dirty that I find I just grab a green scotch brite pad and some wd-40, for new tools I just give them a good wipe with a rag or at best some chrome polish on rare occasions.
briggsguy17
Titusville,PA
Be careful with the greased lightning Bull. It does funky things to aluminum in ultrasonic cleaners. Cost me a $160 Kohler carburetor. The awesome on the other hand is.....well.......awesome. :bounce:
Rickster
SE PA
WD40 on metal tools but I like to clean any plastic handles, grips or meters with Bug and Tar Remover.
lowbucktruck
Foothills, Northern California
Bull:
LA' Totally Awesome Orange cleaner/degreaser really works! :thumbup:
I use it to clean my old/used/rusty tools I've bought at the flea market. Even helps get some surface rust off, if you give the tool a bath in a water/Awesome orange solution for an hour or so... overnight for really funky tools... then rinse the tool with water, dry it and wipe down with WD-40 or PB Blaster. I usually cut the Totally Awesome Orange with some water, don't need it full strength.
tube_guy
I usually wipe down with an oily rag every tool that I touch. Even chrome plated hand tools. Cleans everything up quite well and also prevents rust.
moparmuscle88
Westminster, MD
a "clean" rag to wipe off the grease, if its really dirty, then an old toothbrush and some windex to take the crud out of the recessed areas
but i only do it once a week, any more than that and its just taking away from time to do other things
